Best shallow space bilge pump?
Inverso
City/Region: Seal Beach
PostPosted: Wed Mar 20, 2024 1:31 am    Post subject: Best shallow space bilge pump? Reply with quote
Our stern automatic bilge pump bit the dust. Wondering if anyone has found one that is automatically activated in 1 inch or less of water. Appreciate any ideas.
Don Wilkins, best regards
ATPNW
City/Region: Covington
Vessel Name: Fellowship
Photos: Fellowship
PostPosted: Wed Mar 20, 2024 9:49 am    Post subject: Reply with quote
I am in the process of replacing my Rule float switch with a Ultra Pump switch
“Mini”. It activates the bilge pump in 3/4” of water compared to the old Rule which activates in 2”.
https://www.ultratef-gel.com/product/ultra-bilge-pumpswitch-mini-12v/
jkswor
City/Region: tok
Vessel Name: Missy marie
PostPosted: Tue Mar 26, 2024 11:53 am    Post subject: Reply with quote
Do a search for dry bilge system. Pricy but works in 1/2 inch and less water
I now have a completly dry bilge
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Tue Mar 26, 2024 6:11 pm    Post subject: Reply with quote
I have a space on our Bullfrog with a small stern sump and wanted something low profile to work and not get in the way of feet over the shallow sump area. I used one of these and am happy enough that I now want a spare.
I think we have the 650 auto model
https://www.hardin-marine.com/p-91226-whale-supersub-smart-low-profile-automatic-submersible-bilge-pump-12v.aspx
They have manual and auto matic versions with water sensing, and our kicks on with about 1-1.5 inches of water and off again a few seconds after running empty.
Greg
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
Schuster
City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
PostPosted: Wed Mar 27, 2024 11:57 am    Post subject: Reply with quote
JKSWOR, I did the search of the 'dry bilge system' and saw the video of the entire assembly. I see you have a 25' the same year as mine and I am wondering how this set up works. It seems to be a fairly low volume set up using a small diameter clear plastic tubing. Do you use this in addition to your high volume bilge pump? I am constantly fighting with a wet bilge due to washing down the decks from fish blood or shrimp bait etc and think this may be a good addition but still feel the need for a high volume pump,
(Sea Witch)
25' Cruiser
PostPosted: Wed Mar 27, 2024 8:11 pm    Post subject: Reply with quote
The bilge-b-dry system is not intended as a replacement for the bilge pump but rather an addition to get the last little bit of water. You still need a traditional bilge pump to remove water quickly (and preferably more than one). Ideally, you install one bilge pump as a backup and install it a bit higher than the first large bilge pump. This assures that if the first one gets clogged with debris, the second one will keep the boat afloat.
Page generation time: 0.047s (PHP: 42% - SQL: 58%) - SQL queries: 23 - GZIP disabled - Debug on
