Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
Posted: Fri Apr 19, 2024 12:17 pm Post subject: Repaired Skeg on an used lower unit ok? |
I've found a used replacement lower unit I'm considering buying (40hp Honda). The paint is worn off at the tip of the skeg, and underneath is a dark color that looks like primer. The seller says a part of the skeg the size of a silver dollar was chipped of, but welded and repaired.
Any reason to worry about this? Or just touch up the paint and run with it!?
PS - I have had props welded and repaired before, never any issue, so I figure this is the same? _________________ James Salay - Real Estate Broker / Investor, Engineer, Artist, Fisherman, Canyoneer, Outdoor Enthusiast
Current boats:
1988 16' Angler - "E-fishn-C"
Also:
14.5' Drift Boat - "Wood Zeppelin" |
Joined: 27 Oct 2012 Posts: 3589 City/Region: SW Michigan
Posted: Fri Apr 19, 2024 2:44 pm Post subject: |
I wouldn't worry about it. Any paint you put on it will wear off quickly. |
Joined: 02 Nov 2003 Posts: 21497 City/Region: Pensacola
Posted: Sat Apr 20, 2024 11:03 am Post subject: |
It is not unusual to weld back chunks of skegs. I would want to be sure that all of the seals are still good. The heat from welding can damage the seals. A good professional will be certain that those seals are OK. _________________ Bob Austin
Posted: Thu May 02, 2024 12:52 pm Post subject: |
I knocked the lower part of the skeg off on Journey On. That's aluminum. Had it welded by a good welder and never thought about it until today. I guess the seals were good, never leaked.
Boris |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Thu May 02, 2024 9:16 pm Post subject: |
That is not something I'd worry about at all. And as far as overheating the case from welding? It's possible, but a welder that knows which end of the TIG torch to weld with would not do something like that. |
