2000 22' C-Dory Cruiser w/ Alum Dual Axle Trailer Pilot Hous
rhall
City/Region: ORLANDO
PostPosted: Sat May 04, 2024 5:37 pm    Post subject: 2000 22' C-Dory Cruiser w/ Alum Dual Axle Trailer Pilot Hous Reply with quote
$34,900
2000 C-Dory
22’ Cruiser
2010 Yamaha 90 / 4 Stroke (less than 400 hours)
Custom Cover
Bimini Canopy
Radio
Pilot House
Custom Built Dock-Blocks Floating Dock for extra $6900 only 3 years old.
The planeing hull is nearly flat at the stern and gradually becomes a "V" at the bow!
This 2000 C0-Dory 22' Trawler/Pilothouse comes with a 2000 Honda 4-stroke 90hp engine and is looking good and ready to go today!
The perfect boat for daytime or nighttime fishing trips or just relaxing in the cabin and enjoying the nice V-berth for sleeping over.
There is only a 7-inch draft that allows you go in the most shallow waters, so you don't ground your boat. It planes out in only 9-10mph. The advantage of the pilothouse is it allows you full enclosure while you navigate the waters.
The single Yamaha 90 Motor has enough power to cruise comfortably at 16 mph or max out at 30mph.
There are 4 rod holders to store your poles while you are inside the cabin. Then when your ready plenty of room in the aft
Facebook: https://www.facebook.com/marketplace/item/1418297285472379/
Images: https://drive.google.com/drive/folders/1h3R2OTPblYgp7KvDzbWmZoWh4l-KANIp?usp=sharing
[/img]
Page generation time: 0.048s (PHP: 44% - SQL: 56%) - SQL queries: 18 - GZIP disabled - Debug on
