nwboater
C-Dory Year: 2017
Vessel Name: FastCat
Posted: Tue May 07, 2024 9:38 pm Post subject: Waste holding tank monitor |
I am getting acquainted with our new-to-us 2017 Tomcat and do not see a waste tank monitor -- Has anyone installed a sensor/monitor to show tank levels? Also, how many gallons is the holding tank? _________________ Richard Soto
Tomcat 255 "FastCat"
American Tug "Salty"
Selene 47 "Kika"
Willard 40 "Northstar"
Classic Monk cruiser "Annie B" |
![](templates/subSilver/images/spacer.gif) |
Joined: 02 Nov 2003 Posts: 20923 City/Region: Pensacola
Posted: Wed May 08, 2024 4:31 am Post subject: |
I believe the integral holding tank in the bottom of the commode is still used, and the capacity is approximately 9 gallons.
As I recollect the tanks are translucent enough to see the liquid level.
There are several types of holding tank level monitors--same as used in RV, plus the more expensive monitors which use air pressure on demand. _________________ Bob Austin
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Wed May 08, 2024 12:07 pm Post subject: |
Do the RV monitors ever work correctly on a black water tank? I have had little luck with any of the ones I have had to get them to consistently work correctly. It's really good you can see the level. I wish I could on my Winnebago. |
Posted: Wed May 08, 2024 12:43 pm Post subject: |
T.R. Bauer wrote: | Do the RV monitors ever work correctly on a black water tank? I have had little luck with any of the ones I have had to get them to consistently work correctly. It's really good you can see the level. I wish I could on my Winnebago. |
The black water monitors on our last two RV's (a period of about 17 years) have worked well. They are external tank monitors. The 42' diesel pusher had a 100 ballon blackwater tank. Our Current 25' on a Mercedes sprinter chassis has a 50 gallon blackwater tank. The grey and fresh water also work well. |
Joined: 27 Oct 2012 Posts: 3412 City/Region: SW Michigan
Posted: Wed May 08, 2024 3:46 pm Post subject: |
You need the probe type sensors, not the mechanical float type in the grey and black water tanks. These are harder to gunk up and malfunction. |
Joined: 01 Mar 2005 Posts: 7450 City/Region: from island boy to desert dweller
Posted: Wed May 08, 2024 8:34 pm Post subject: |
To be somewhat delicate about it (and that is not my strong suit) - you are looking down into the tank when you flush... you will know when it is getting full.
We have been RVing for over 30 years, and the SeaLand Marine/RV toilet in the later C-Dorys is easy to use, especially compared to a more typical marine toilet. A few things that have worked well for us:
* Use rapidly dissolving toilet paper (Angel Soft works well and is easily availablel).
* Consider putting a ball valve into the water line feeding the toilet - using the foot pedal will fill your tank faster when you can't control the flow of fresh water into the toilet.
* Use liquid RV black tank products without formaldehyde - it will keep the odor down and break down the solids faster.
* We used a squeeze bottle with fresh water in it as a rinse instead of the foot pedal... it really saves on the tank "storage."
* After a pump out, run more fresh water into the holding tank and pump it out again. Put the RV holding tank stuff in with a bit of fresh water when done with the pump out.
* We used the shower in the head on our CD-25. Water will get into your toilet bowl from the shower. My wife made a waterproof cover to put over the toilet when we showered - again, saving that holding tank from filling faster than necessary.
* All this sounds like a bunch of work - it isn't. Most of the time, with two of us on the boat full-time, we needed to pump out about once a week +/-.
Congrats on the upgrade to the TC255 - great boat!
Jim |
