Correct prop for 23 Venture with Suzuki 140
trailrun99
City/Region: Renton
C-Dory Year: 2022
PostPosted: Tue May 21, 2024 4:38 pm    Post subject: Correct prop for 23 Venture with Suzuki 140 Reply with quote
My 23 Venture came with a 17 inch pitch, SS prop. It seems to be under propped so I was thinking about switching to a 19 inch pitch prop. Does anyone have advice on what prop works well with my combo? Also, should the pitch change if I switch to an aluminum prop?
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Tue May 21, 2024 5:18 pm    Post subject: Reply with quote
Hi Roger,
I can't speak for a SS prop but our 23 Venture/Suzuki 140 came to us new with a 21 inch aluminum prop. I was told that it was properly pitched for our boat from Sportcraft Marina but soon discovered that it was not. I could only get about 5,500 rpm out of the motor when properly trimmed. The prop may have been good for when the boat is lightly loaded but we run our boat heavy for fishing and extended travel in Canada. I switched to a 19 inch Suzuki aluminum prop (3x14x19) and now get a little over 6,000 when properly trimmed. We keep the 21 inch as an emergency spare. Gary
Gary F
PostPosted: Tue May 21, 2024 8:07 pm    Post subject: Reply with quote
If you are going to change the prop around go with aluminun until you find the right one then go with a stainless. I really like 4 blade props on stern heavy boats which your is with the motor.
trailrun99
City/Region: Renton
C-Dory Year: 2022
PostPosted: Thu May 23, 2024 12:11 pm    Post subject: Re: Correct prop for 23 Venture with Suzuki 140 Reply with quote
I think I will try a 19" pitch from sportcraft in Oregon.
PostPosted: Thu May 23, 2024 3:49 pm    Post subject: Reply with quote
Agree with Tom about the stern lift and 4 blades with the Suzuki 140. I have a 2007 140 on my Caracal Cat, with a SS 4 blade. See if a dealer has a loan program where you can try a prop for a day and if it works;Good, if not then try a different prop.
The Newer 140's put out about 20 more in mid range and turn slightly higher at the rev limiter (6200 to 6300). If you really want more power out of the 140, let me know. Mark Grove (who recently sold Wefings boat dealership) has a way to get 170+ hp and better speed and economy in mid range on these newer motors.
I run SS props, unless planing to run into debris or grounding. The SS is thinner slightly more efficient because less flex than the Aluminum.
PostPosted: Thu May 23, 2024 9:57 pm    Post subject: Reply with quote
Is he running that company that reflashes the computers or is he just sending stuff there?
Page generation time: 0.0246s (PHP: 67% - SQL: 33%) - SQL queries: 23 - GZIP disabled - Debug on
