Port livewell hose replacement
Finally2
City/Region: Los Osos
Vessel Name: Badfish
Photos: Finally2
PostPosted: Mon Jul 15, 2024 2:35 pm    Post subject: Port livewell hose replacement Reply with quote
So my port livewell hose broke due to old age. I attempted to replace it with sturdy clear tubing you’d use for bilge pumps and whatnot but it just would turn/twist correctly… so I took a heat gun to it but still in order to turn/twist correctly to fit to the discharge port it pinched down a bit… this will probably affect my drain rate and increase chances of stuff clogging it. I do use it as a livewell…
I’ve searched here and the only apparent matching discussion labeled “CRUMBLING HOSE” won’t open.
Is the replacement hose a 1.5in pool hose? Prolly 3ft? Thanks!
-Zac
Page generation time: 0.0236s (PHP: 54% - SQL: 46%) - SQL queries: 18 - GZIP disabled - Debug on
