SOLD - 2006 Cape Cruiser 23' with trailer $55K- St Pete Fla
Cjames
City/Region: St. Pete
Photos: CJames
PostPosted: Sun Sep 01, 2024 3:28 pm    Post subject: SOLD - 2006 Cape Cruiser 23' with trailer $55K- St Pete Fla Reply with quote
We have been stricken with “2 footitis” wanting to do some longer distance cruising!
Very clean and dry boat (sealed anchor locker and cabin cockpit joint). Minor small repaired dings on hull, but no gelcoat crazing or delamination on deck or hull, excellent condition for a 2006 as she has always been stored under cover.
Cape Cruiser 23 is the original hull mould of the C-Dory Venture 23.
• LOA 22’9″
• Beam 8′
• Headroom 6’4″
• Weight 3000 lbs
• Cockpit 5’1″ long x 6’1″ wide
• Height on Trailer 9′
• Draft (with fuel, less gear) 12″
1. Aluminum Magic Tilt tandem trailer with surge brakes(new supports and bunks). Hard bottom paint for trailering.
2. Honda 135HP engine 553 hours, runs great, top speed 30+ mph- cruising 15-18 mph. Hydraulic steering.
3. 2023 new AGM starter battery group 24, new AGM house battery group 31 -both charger thru alternator via Blue Sea ACR auto charging relay. Victron BT enabled Smart Shunt battery monitor.
4. Trim tabs
5. extra propeller
6. 60 gallon fuel capacity
7. 2 new Attwood bilge pumps
8. 2 shore power cords (30A and 15A)with 10A ChargePro dual bank
9. Garmin GPSmap 1042xxv chart plotter
10. Garmin GMR 18HD+ Radar
11. Cobra Marine fixed mount GPS enabled VHF with DSC
12. Electric anchor windless with helm and remote control
13. 1 Lewmar 14 Delta anchor and 1 Danforth stern anchor, 100 ft strand line- 30ft Acco G4 chain,
14. Coleman Mach roof top 8000 btu AC unit with heat
15. Sunbrella full bimini and camper enclosure with vinyl and screen, full custom boat/engine cover for storage. Door, window and hatch screens. Spacious cockpit with removable table and 2 seats.
16. Dometic Tundra 2.2 CF fridge
17. Wallas burner/heater, removed but complete unit will be with boat. We preferred portable propane cooker top.
18. Sink with 20 gallon fresh water supply (new water pump and pex line), cockpit washdown connection
19. Sunbrella upholstery in excellent condition. V- berth and dinette located along the port side of cabin that converts into 6’4” berth.
20. Excellent storage for a 23 ft boat- under dinette seats and galley storage, shelving over galley and table. Foam partially removed under v-berth with 2 access hatches.
21. New LED lighting
22. dive/swim ladder
23. 2 portable Predator 2k watt generators with parallel wiring and pigtail (runs AC). Running condition unknown as we never used them.
C James
Cjames
Photos: CJames
PostPosted: Mon Sep 02, 2024 10:03 am    Post subject: FYI- My Yahoo account has expired Reply with quote
I only created it for C-Brats and due to inactivity, it was deactivated. If you need additional info please email to: Versatron@aol.com
Sorry for the inconvenience.
Cherita James
Cjames
Photos: CJames
PostPosted: Thu Nov 07, 2024 5:31 pm    Post subject: SOLD 2006 Cape Cruiser 23 foot with trailer $55K- St Pe Reply with quote
Despite a couple of hurricanes causing some delays she is SOLD!
Page generation time: 0.1863s (PHP: 23% - SQL: 77%) - SQL queries: 20 - GZIP disabled - Debug on
