Cruiser 16 Replacement Windows
Idlechater
City/Region: Snohomish
Vessel Name: Brutus
Photos: Brutus
PostPosted: Sat Sep 07, 2024 1:32 pm    Post subject: Cruiser 16 Replacement Windows Reply with quote
Hello - Looking at a Cruiser 16 that has pretty corroded windows. Is there a place that sells replacement windows?
PostPosted: Sat Sep 07, 2024 3:06 pm    Post subject: Reply with quote
This outfit: is Advantec Store and should be able to supply new windows.
Is it the frame or glass? If it is the frame, just start sanding--and get down to bare aluminum frame clean with soap and water then dewax solvents--then treat with Alodine, Bonderite, a two part strontium or Zinc Chromate primer, and coats of exterior enamel. "Hatteras" White should match the boat color of white.
If the glass has bad spotting, then use "Amaz" Amaz glass cleaner. It is a glass stain remover, mild polishing compound which can do wonders. [/url] This is usually in stock at Ace Hardware.
Idlechater
Vessel Name: Brutus
Photos: Brutus
PostPosted: Sat Sep 07, 2024 3:18 pm    Post subject: Reply with quote
Thank you very much for that information!!!
Page generation time: 0.0569s (PHP: 26% - SQL: 74%) - SQL queries: 16 - GZIP disabled - Debug on
