shad
Vessel Name: C-Squatch
Photos: C-Squatch
Posted: Sat Jan 25, 2025 8:02 pm Post subject: Fuel Selector Valve Label |
I took inspiration from an earlier post about fuel selector valve labels and designed a 3D printed option for the Moeller/Sierra/Anderson three-way fuel selector valve. If anyone is interested, I can print and mail you one or send you the file to print your own...or I can bring some to the Friday Harbor 2025 gathering assuming I am able to attend.
My fuel selector valve body protrudes a bit, and a perk of the wider center hole is that it can be slipped over the handle if it is corroded on. I can make some tweaks to the design if yours has starboard/port reversed or you want the center hole sized to the post only.
Compatible fuel selector valve: https://www.fisheriessupply.com/moeller-marine-fuel-valve-three-way-female-nptf-valves/033305-10
Inspiration:
http://www.c-brats.com/viewtopic.php?t=17275
I have a small CNC mill, so if there is enough interest I can mess around with a CNC'd option similar to the one linked in the original thread.
--Shad |
clayhubler
Joined: 03 Aug 2019 Posts: 374 City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
Posted: Sat Jan 25, 2025 8:31 pm Post subject: |
Looks good, I like it _________________ Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser |
Xtraplus18
Joined: 14 Jan 2022 Posts: 57 City/Region: Battle abound
Vessel Name: C-Handler
Photos: C-Handler
Posted: Mon Jan 27, 2025 3:58 pm Post subject: |
Me too! Great job!!! |
gstraub
C-Dory Year: 1998
Vessel Name: EnDoryFun
Photos: EnDoryFun
Posted: Tue Jan 28, 2025 5:39 am Post subject: |
This is great! I've been fighting that label battle for a while. I'd definitely be interested in getting one. I just need to verify my orientation, etc., and I'll send you a message. _________________ Gerhard |
shad
Photos: C-Squatch
Posted: Tue Jan 28, 2025 11:22 am Post subject: |
gstraub wrote: | This is great! I've been fighting that label battle for a while. I'd definitely be interested in getting one. I just need to verify my orientation, etc., and I'll send you a message. |
Sounds good, Gerhard.
To anyone else who is interested, feel free to PM me the clockwise orientation "A" or "B" below and the center hole size. If "B", I will probably shorten "Gasoline" to "Gas" for better fitment.
Orientation "A" - Off, Gasoline, Port, Starboard
Orientation "B" - Off, Gas, Starboard, Port
Center Hole Size: Big or Small
Include your mailing address and I will get 1-2 in the mail once printed. I do not anticipate there will be too many requests for a label, so free of charge as of this point.
The label is 3in in diameter, 1/8in thick, and printed in PETG material. Black and white only. In theory it should last a while in the sun. We'll find out...
--Shad |
Posted: Tue Jan 28, 2025 1:55 pm Post subject: |
Hey Shad,
If you are going to be at the Friday Harbor event, and don't mind printing out and bring one for me, I'd like to have one. That is assuming it would be easy to change the words a bit. My valve looks like the one you posted, but positions are different. Using clock positions, 12:00 and 6:00 are off, 3:00 is MAIN and 9:00 is AUX. Small hole suffices, as I can take the pointer knob off. Thanks. Colby |
shad
Photos: C-Squatch
Posted: Tue Jan 28, 2025 2:17 pm Post subject: |
colbysmith wrote: | Hey Shad,
Hi Colby,
I should be able to make the tweaks and print a couple out for you. My tentative plans are to be at Friday Harbor from Fri-Sun. Otherwise, I can mail them to you sooner.
--Shad |
Posted: Tue Jan 28, 2025 2:19 pm Post subject: |
shad wrote: | colbysmith wrote: | Hey Shad,
Hi Colby,
--Shad |
Many Thanks! Colby |
