1998 Honda BF90 spare parts to carry
Ken O
City/Region: West Yellowstone
State or Province: MT
C-Dory Year: 1990
Vessel Name: Ravens' Roost
Photos: Ravens’ Roost
PostPosted: Mon Feb 03, 2025 9:51 pm    Post subject: 1998 Honda BF90 spare parts to carry Reply with quote
Our C-22 came with and still has a 1998 BF90. The hours are unknown, but probably are low. The motor runs flawlessly. The oil still looks like honey at oil change time.
My question is: what spare parts should I carry, and what maintenance might I be missing.
Every season I do all the standard stuff (change motor oil, filter, gear oil, check for water in the lower unit (never a drop), gap spark plugs, lube, change impeller every other year, etc.
I carry a spare prop, several nuts and prop washers, spark plugs, ignition coils, fuel pumps, filters, hose and clamps, impeller kits, oil and filters, gear oil, and appropriate tools, including a multimeter.
I don't want to carry a lot more parts, but I don't want to overlook a commonly needed part or maintenance task.
Any experience with this motor or the BF70 would be appreciated.
"If it were easy, everyone would be doing it." --Circumnavigator and author Larry Pardey.
Flashyfish
City/Region: Windsor
C-Dory Model: 19 Angler
Vessel Name: Kraken
PostPosted: Tue Feb 04, 2025 12:14 am    Post subject: Reply with quote
If that year motor has a flexible timing belt, instead of a timing chain, probably time to have that replaced.
I am not sure if that year is an interference type motor, but a broken timing belt is bad at any time.
PostPosted: Tue Feb 04, 2025 3:15 am    Post subject: Reply with quote
I have owned several Honda 90's and 150. The kit is very much like you say. Complete took kit, incuding torque wrenchs. Robertson as well as close work slot and phillips scew driver, Metric and SAE sockets and open/box wrenches.
I do add in extra drain plug for both the engine oil and lower unit. I also have the proper steering fluid in a quart size and tubing to bleed the hydraulic system.
Be sure to have a prop wrench and extra prop/props on board.
Ken O
C-Dory Year: 1990
PostPosted: Tue Feb 04, 2025 9:36 am    Post subject: Reply with quote
Thanks guys. I forgot to mention that I did replace the timing belt when I got the motor. It is an interference engine--same block as the older Accords. Indestructible as long as they have oil and an intact timing belt! Bob, thanks for the reminder. I also do have the drain plugs and the socket for the prop. So far, so good.
PostPosted: Tue Feb 04, 2025 11:33 am    Post subject: Reply with quote
I have an '08 BF90D. I do the scheduled maintenance. I carry a spare prop, the tools to change it, and a quart or two of engine oil.
However, I don't usually go off into the uncharted wilds in my boat.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Feb 04, 2025 2:27 pm    Post subject: Reply with quote
It really depends on a ton of things how much I bring. But I always carry a spare prop, some basic stuff to repair electrical crap, hydraulic oil, duct tape, and basic tools. I have never carried extra spark plugs, fuel filters, or 3/4 of that stuff people have listed. Maybe I should....But I have found from thousands of hours of experience that if you are up on your maintenance, those things just don't randomly fail unless something really exceptional occurs. I supposed it's just risk management and what you're comfortable with that drives our decisions...I think your list is great. And it's important we keep Sea Tow in business.....lol....
Roamad
City/Region: Sacramento
C-Dory Year: 1988
C-Dory Model: 22 Classic
Vessel Name: Fika
Photos: Roamad
PostPosted: Tue Feb 04, 2025 6:42 pm    Post subject: Reply with quote
Timely for me as well since I’m new to the BF90. Does anyone know whether the 2001 engine has a timing belt or chain?
Now: 1983 22’ C-Dory Classic, 2001 Honda 90hp
Then: 1988 16’ C-Dory Angler, 2008 Mercury 60hp
PostPosted: Tue Feb 04, 2025 8:40 pm    Post subject: Reply with quote
The several items I would say are essential are: spare prop, and tools to change.
Fuel filters--even though we all try and do preventive maintenance you can get bad fuel.
I even used a "surplus" piece of Hypalon on an inflatable to make a fuel pump diaphragm on the boat's outboard. It was going to be a very long paddle home...actually we had a 3 hp outboard as the kicker for the 25 on the dinghy.
Ken O
C-Dory Year: 1990
PostPosted: Tue Feb 04, 2025 9:54 pm    Post subject: Reply with quote
Your engine should have a belt:
https://www.boats.net/product/honda/14400-ZW1-004?ref=27eb247b9671102e8a03358959b733876e6b1883
This may not be the exact belt for your motor, but it is for a 2001 BF90, which tells me all versions would have belts.
Roamad
C-Dory Year: 1988
Vessel Name: Fika
Photos: Roamad
PostPosted: Thu Feb 06, 2025 3:47 pm    Post subject: Reply with quote
Thank you!
PostPosted: Fri Feb 07, 2025 9:35 am    Post subject: Reply with quote
The BF90Ds have a chain.
Schuster
City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
PostPosted: Fri Feb 07, 2025 11:11 am    Post subject: Reply with quote
Looking on Utube for the answer as to whether the BF90 has a belt or chain. The best i could find is that the change over between belt to chain was somewhere around 2006 when they reconfigured the entire engine. One video I saw was for a 2005 BF 90 timing belt change out. so they still had a belt in 2005.
As far a carrying a belt as an emergency repair, well if you bring your manual and are a proficient mechanic then maybe but for the rest of us, probably unnecessary added cargo.
(Sea Witch)
25' Cruiser
PostPosted: Fri Feb 07, 2025 1:47 pm    Post subject: Reply with quote
If the timing belt lets go while the motor is running you will need to be a very expert mechanic with lots of spare parts and tools to ever get it working again. On the other, if you're not, you'll have a nice anchor.
Schuster
Photos: Sea Witch
PostPosted: Sat Feb 08, 2025 10:27 am    Post subject: Reply with quote
SSBOL, you're correct. It is my understanding that if the belt breaks while running that the cam shaft stops turning but the crankshaft will continue to turn. As a result timing is thrown off and as a result valves and push rods get bent by the piston pushing up into the valve and any number of problems can stem from that including a damaged piston, bent or broken valves, a damaged cylinder wall or head and possibly damaged camshaft. I guess the prudent course of action is to check the timing belt occasionally for wear.
Ken O, I would recommend that if you haven't looked at the belt or had a mechanic look at the condition of the belt that it is new to you, you should inspect it to know where you stand from the git go. Good luck.
T.R. Bauer
PostPosted: Sat Feb 08, 2025 11:09 am    Post subject: Reply with quote
I would say checking the timing belt is a very good idea. But with that said, they last about forever for most boaters.
Page generation time: 0.0427s (PHP: 62% - SQL: 38%) - SQL queries: 32 - GZIP disabled - Debug on
