Mold issue on exterior fuel tank walls
skiptowns98033
City/Region: Cornet Bay
Vessel Name: Plan C
PostPosted: Mon Mar 31, 2025 1:41 pm    Post subject: Mold issue on exterior fuel tank walls Reply with quote
I've been pretty meticulous cleaning mold from the both inside walls of the fuel tanks under the motor well, in the starboard battery compartment and in the area back around the drain plug of my 22' '05. I figured there was mold on the other sides but, until I took off the panel protecting the tank (the one with the cut out to watch fuel levels), I had no idea of how bad it was!
I managed to clean the top and front side of the tank but can't get to the outside or back without removing the entire fuel tank? I dread even doing that much on the other tank - removing that front panel is not easy.
Anyone got thoughts or ideas?
PostPosted: Mon Mar 31, 2025 6:42 pm    Post subject: Reply with quote
Spray one of the mold abatement solutions on the area, allow to sit for several hours, and then spray with water. I have used garden sprayers to get into tight places,
skiptowns98033
Vessel Name: Plan C
PostPosted: Tue Apr 01, 2025 1:40 pm    Post subject: Reply with quote
Thanks Bob! I'm using a bleach and water mix but it sure is difficult to get in behind some of those tight places! As long as I give everything a good rinsing, do you think there's any concern for the bleach damaging or eroding 'stuff'?
PostPosted: Tue Apr 01, 2025 9:27 pm    Post subject: Reply with quote
I have used similar solutions and had no problems. Just don't spray on electrical contacts, batteries, etc.
JimTid
City/Region: Jacksonville
Vessel Name: Lucy
PostPosted: Wed Apr 23, 2025 8:43 am    Post subject: mold Reply with quote
I use a product called Wet and Forget to retard future mold growth. It is sold at Lowes and on Amazon.
Page generation time: 0.0533s (PHP: 30% - SQL: 70%) - SQL queries: 22 - GZIP disabled - Debug on
