SOLD - Fully Loaded 2006 C-Dory 16' Cruiser $24,900
dslocombe
City/Region: Marysville
Photos: dslocombe
PostPosted: Fri Jun 06, 2025 1:27 am    Post subject: SOLD - Fully Loaded 2006 C-Dory 16' Cruiser $24,900 Reply with quote
This sturdy 2006 C-Dory 16' Cruiser is fully loaded and ready for leisurely day or overnight fishing trips, weekend cruising or exploring fresh or salt water shorelines. With its modular Sunbrella and stainless-steel full cover enclosure system you’ll be completely protected in any kind of weather. With two batteries instead of the normal one and the 100W solar panel you’ll have power for overnight stays without having to run the engines. The Tri-Metric battery monitoring system will always let you know how much current you’re using and the state of your batteries so you’ll know if your batteries need recharging. And you can recharge your batteries three ways: with the alternator on the Honda 50, the solar cell charging system and the Cabela's 20A Pro-Series battery charger.
For those who want to drop a hook in a quiet bay and stay overnight, you’ve got a reliable anchoring system with your Delta anchor and a cozy cabin that sleeps two in the V-berth. And to play your tunes you’ve got an am/fm radio and cd player. You can also play music or audio books on your phone or tablet using our Bluetooth fm transmitter. This allows you to play audio content using a wireless Bluetooth connection through the fm radio and have it played on the stereo speakers in the cockpit. Your Standard Horizon VHS radio provides you emergency marine communication and weather information. And if you need to use a laptop or other 110V device, you have a 300W inverter to power it. Multiple USB charging adapters are also available to charge your phone, tablets or other USB devices.
With two 6.6-gallon fuel tanks for the fuel-injected Honda 50hp 4-stroke outboard, you’ll have more distance to explore before having to refuel. For fisherman, the Honda 5hp outboard (also 4-stroke) will provide a quiet and efficient trolling motor and can be used as a backup if the “big” Honda. We've just had the oil and filters changed and filled the fuel tanks with fresh fuel so she is ready for a fun day of fishing and exploring. And with the eight stainless steel Burnewiin gunwale mounts there’s all kind of options to mount downriggers, fishing poles and other fishing accessories in the cockpit where we used to run our two Scotty downriggers. This C-Dory is lightweight and a dream to tow and because she’s so compact, she can be stored in your backyard just as we did. We’ve taken good care of her and we think you’ll find her a joy to own.
Slocombes’ 2006 C-Dory 16’ Cruiser Equipment Specifications
Hull Features
·       16’ Fiberglass hull, weight 900 lbs. empty
·       Two slide opening windows
·       Front opening hatch over v-berth
·       Windshield wipers
·       Stainless steel cabin-top handrails
·       Stainless steel cockpit handrails
·       3 ea. Deck lights for night navigation
·       Running and anchor lights
·       Yeti-type cooler mounted on transom
·       Folding stainless steel ladder
·       Stainless steel anchor roller
·       Anchor Rode includes:
    * 14lb Lewmar Fast Set Delta anchor
    * 15 ft of 1/4” galvanized chain
    * 140+ ft of 3/8” 3-strand nylon line
·       Sunbrella yacht acrylic and stainless-steel full cover enclosure system provides complete cockpit protection from wind and rain and includes:
    * Bimini top
    * Cockpit side panels with zippered roll-up windows
    * Cockpit back panel with zippered roll-up window
    * Cabin entry panel with zip up door
    * Cockpit night light, usb-chargeable
    * Sunbrella cover for side and back panels for storing them under the v-berth cushions
Outboard Motors and Accessories
·       Honda BF50D 50hp fuel injected 4-stroke outboard motor with electric start, <45 hrs. running
·       Honda BF50D Shop and Owner manuals
·       2 ea. Honda 6.6-gallon fuel tanks
·       Permatrim Performance Foil for the Honda 50 increases performance and efficiency
·       Marinetech Transom Saver to secure the Honda 50 to the trailer while traveling
·       Honda BF5A 5hp 4-stroke manual start outboard for trolling
·       Honda BF5A Shop and Owner manuals
·       1 ea. Honda 3-gallon fuel tank
·       Spare Parts Kit with parts for both motors
Fishing Accessories
·       8 ea. Burnewiin stainless steel GM650 Gunwale mounts (7 in cockpit area, 1 on forward) Go to the Burnewiin web site for more info on accessories for these mounts.
·       3 ea. stainless steel fishing rod holders
·       1 ea. Burnewiin rod holder that fits into Burnewiin gunwale mount
·       1 ea. Burnewiin fillet knife that fits into Burnewiin gunwale mount
·       1 ea. Magma Fish Cleaning station with adaptor to fit in a Burnewiin mount
·       2 ea. Scotty Downrigger 12V power sockets in the cockpit (We used these to power two Scotty Downriggers with Burnewiin mount adapters that worked well with poles held in Burnewiin rod holders.)
12V Power System and Accessories
·       1 ea. Interstate 24M-XHD Flooded Marine Battery
·       1 ea. Interstate 31M AGM Battery
·       Tri-Metric TM 2025-RV Battery Monitoring System
·       Cabelas Pro Series 20A 2-bank 12V battery charger
·       Honda BF50D Alternator provides up to 15A charging current
·       Grape Solar 100W Solar Panel
·       Sunsaver 15A 12V Solar Controller
Safety Features and Accessories
·       2 ea. Stern Adult Life vests
·       2 ea. Throwable life cushions
·       Throwable orange life ring
·       Orion 12-gauge ariel flare launcher
·       Handheld flares
·       Air Horns
·       BC Fire Extinguisher
·       Flashlights with strobe (battery-operated & usb-chargeable)
·       Non-slip rubber floor tiles in cockpit and cabin
·       Rule-Mate 1100gph 12V bilge pump
·       Manual bilge pump
Navigation and Electronics
·       Garmin Echomap Plus 73SV 7” touch-screen chart plotter, fish finder and depth sounder with charts for US lakes.  Charts for Puget Sound and the San Juan Islands can be purchased on digital media and easily downloaded into the chart plotter.
·       Lowrance X67c color display fish finder and depth sounder
·       Ritchie compass
·       Standard Horizon Eclipse DSC+ VHS and weather radio
·       Bestek 300W 12V to 110V AC Power Inverter with dual 110V sockets and dual USB sockets
·       Aquatic AV AM/FM/Weather band radio and CD player
·       Bluetooth 5.3 FM Transmitter for playing Bluetooth audio content on your phone or tablet through the FM radio and cockpit speakers
·       Multiple USB and 12V power and charging sockets
Cabin Features
·       Steering wheel and Honda 50 starter and controls
·       AM/FM/Weather band Marine radio and CD player
·       2 ea. rotating chairs that can face forward or aft
·       Interstate 31M AGM battery stored underneath passenger chair
·       V-berth with storage underneath
·       Thetford Porta-Potti beneath center V-berth
·       Detachable table that can be used as a chart table or a dining table
·       Overhead cabin lights, 12V and battery-powered
·       V-berth USB-chargeable overhead light
·       Electrical control panel
Miscellaneous
·       2 ea. folding chairs that fit in the cockpit enabling 4 people to ride
·       2 ea. stereo cockpit speakers
·       Extendable boat pole
·       Bimini ceiling cockpit light for use at night
·       3 ea. bumpers
·       2 ea. Bass Pro Shops stretch dock lines
·       EZ Loader trailer with swing-away trailer jack and spare tire
PostPosted: Fri Jun 06, 2025 1:53 pm    Post subject: Reply with quote
What a well scripted ad for a C Dory! This seems like one of the best equipped 16's I have seen.
The Craigs List:
This posting has been flagged for removal.
. so no photos. Apparently you have accidentally violated the CL terms of use. I have never seen this before, and I am sure is not intentional.
You do not seem to have a photo album. You can add photos directly to a post on the Boats for sale by owner thread.
I would love to see photos. Might I buy a 16 cruiser?..well, doing as well as I am currently at almost 89, I would rather buy a 16 than have cosmetic dental work!
PostPosted: Sat Jun 07, 2025 8:58 am    Post subject: Reply with quote
The photographs show an exquisitely built out and maintained boat. It looks like new, and is probably one of the best outfitted 16' C Dorys I have seen. The seller apparently had some minor details with Craigs lists "rules", and tells me in a PM that it will be posted again.
I think anyone looking for a 16 cruiser should strongly consider this boat. If it were closer to me, I would buy it without hesitation, if the motors check out at sea trial. (Which I suspect they will easily.)
PostPosted: Sat Jun 07, 2025 10:23 am    Post subject: Reply with quote
Great photos that really show the boat and condition! Combined with the written details, this shows a well-equipped boat. This is how a for-sale ad should be presented.
Page generation time: 0.0269s (PHP: 77% - SQL: 23%) - SQL queries: 21 - GZIP disabled - Debug on
