Need Help with Venture 23 Boat Lift Bunk Specs/Hull Deadrise
SEdowneast
City/Region: Lake Murray
State or Province: SC
PostPosted: Sun Jul 06, 2025 1:46 pm    Post subject: Need Help with Venture 23 Boat Lift Bunk Specs/Hull Deadrise Reply with quote
Hello Everyone, well I guess I will be part of the group in earnest soon, as we’ve just ordered a new Venture 23. Very excited about the adventures ahead!!
I will need to get my boat lift bunks built for the new boat and am looking for the specs for them. If anyone with a Venture 23 could help, it would really be appreciated.
I am specifically looking for the deadrise angles for the hull at the stern and the angle of the hull directly below the front of the midship cleat. The “level” tab of the “Measure” app on an iphone can be used to take angle measurements.
I am also looking for the centerline distance between the bunks if someone has those….or, even the same measurement of the back bunks of a trailer that has been set up specifically for a Venture 23.
Look forward to being active with the group in the future!
Thanks so much!!
Tom Hruby
City/Region: Lacey
C-Dory Year: 2024
Vessel Name: WATT NOW
Photos: WATT NOW
PostPosted: Sun Jul 06, 2025 4:11 pm    Post subject: Reply with quote
Have you tried contacting NMI (Northwest Marine Industries) that is building your boat? I am sure they have all these technical specs since they set up the trailers for these boats as well.
SEdowneast
PostPosted: Sun Jul 06, 2025 5:52 pm    Post subject: Reply with quote
I have asked the questions via the dealer but haven’t gotten a response yet. I think they are quite busy these days! Thinking someone on here might have already been down this road, this my post. Thanks!
PostPosted: Sun Jul 06, 2025 7:07 pm    Post subject: Reply with quote
Interesting questions: are you going to change the angle of the boat surface (upper surface), by the angle of the deadrise of the various stations in the hull. I am not sure I have ever seen that done. Certainly now many of the lifts are fitted for the deadrise aft--this is especially important in high dead rise boats, such as Contender (up to 26* at the transom.
I have a 25 year old lift, which I have put boats from flat botton, minimal dead rise, a 27' boat with 18* deadrise, a several 20 foot boats with 18 to 20 degree deadrise at the transom, and two different catamarans on--all the same: two 2X10 true dimensional salt water treaded timbers on each side. They have remained the disance apart most of the time--and that was for 8' beam catamarans. I would have had to build (custom wood work, which I would do my self with a power planer) for each boat doing that. No ill effects on any of those boats from the way the bunks were set.
SEdowneast
PostPosted: Mon Jul 07, 2025 6:17 am    Post subject: Reply with quote
Well since the deadrise of this boat progresses from somewhat flat, say 6 degrees at the stern, to much more towards the bow, I generally bevel the edges of the wood bunks to similar angles. By doing so the boat will sit flat and is fully supported by the entire portion of the edge not just maybe a corner of the wood bunk. It’s not hard to do if you know what angles to start with and finish. Additionally, you can look at the trailer bunks to see where the increase in angle begins as you move forward. Of course on most boats the stern Deadrise is carried all the way forward, but not on C Dorys, thus the information request. Thanks!
PostPosted: Mon Jul 07, 2025 11:17 am    Post subject: Reply with quote
If you have the skills to do what you propose, then go for it. Hopefuly you have a power planer, or even a good draw knief and long planes. Even the extreme deep "V" boat have variable deadrise. The early C Dory had flat bottoms. Many boat trailers have the bunk boards flat, but they articulate and then they twist and presume the proper angles, Forward bunks resume the proper angle, as their mount moves. One could do the lift bunks the same way, but that might bring the bunks higher. How much water under your lift? You want enough so you can float the boat off in even the extreme low tides.
I see lots of new boat trailers, which have a constant deadrise built into the lumber set on edge, but it is not variable. So there is compromise. The most weight of most small outboard powered boats is concentrated at the stern. So these trailers concentate on the stern deadrise. (Where the "deadrise" is measured in the "specs" on boats is noted.)
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Mon Jul 07, 2025 11:49 am    Post subject: Reply with quote
SEdowneast, I think I can help with those measurements. PM sent.
Gary F
DayBreak
C-Dory Year: 2018
Photos: DayBreak
PostPosted: Mon Jul 07, 2025 1:07 pm    Post subject: Reply with quote
....or if this helps...The bottom bunks are 12' x 6 " and separated 32" apart at the transom, having a 4 degree deadrise. The bottom of the hull remain totally flat at 0 degrees up to about 7' where the angle increases in about 1 degree increments up to about 4 degrees at the end of the 12' bunk. These measurements were taken with my iPhone. Hope this helps and congratulations on the purchase of your new 23 C-Dory Venture and joining the group.
SEdowneast
PostPosted: Mon Jul 07, 2025 4:51 pm    Post subject: Reply with quote
Such great folks and valuable insight on this forum!! So appreciate it!
For my boat lift I will basically rip the bunk boards with a circular saw at the required angles. The boards stand up attached to the beam brackets. Not really hard to do as long as you know what angles to cut.
Page generation time: 0.0875s (PHP: 23% - SQL: 77%) - SQL queries: 23 - GZIP disabled - Debug on
