Bennett Trim Tab Switch not working
PvL
City/Region: Sunshine Coast
Vessel Name: Lately
Photos: Latley
PostPosted: Thu Jul 10, 2025 9:23 pm    Post subject: Bennett Trim Tab Switch not working Reply with quote
I have a Bennett Euro style model Ben ES-2000 controller for my trim tabs. The right switch has lost resistance and does not work. The switch just flops back and forth. What might the problem be?
I have checked the wiring, hydraulics etc All good.
Is the switch just worn out and needs to be replaced or can I fix the mechanism ... your thoughts?
Thanks in advance.
PvL
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Thu Jul 10, 2025 10:40 pm    Post subject: Reply with quote
I had the same problem. The base of the switch broke, plastic you know what. I had to order a new switch, which included both port and starboard switch rockers. Easy to find out by taking off switch rockers. You'll see that one is broken.
https://www.hodgesmarine.com/benes2000-bennett-euro-rocker-switch-es2000.html?srsltid=AfmBOopxMkc8ok4jEnEi5LgpUAdP8wwbNnpIwtZCG78TZY9ipRaNGUk3
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
PvL
Vessel Name: Lately
Photos: Latley
PostPosted: Fri Jul 11, 2025 1:00 am    Post subject: Bennett Trim Tab Switch not working Reply with quote
Thanks for the prompt reply. That is what I thought
Page generation time: 0.0274s (PHP: 56% - SQL: 44%) - SQL queries: 20 - GZIP disabled - Debug on
