Donald Tyson
Photos: Thistle
Posted: Tue Jul 08, 2025 2:43 pm Post subject: Charging issues |
Took a shakedown cruise in the Chesapeake over the weekend and enjoyed the sunshine and warm weather. I hope you all enjoy your holiday weekend as well.
I had some significant issues with the batteries and need to learn the cause. If I turned on the batteries to All then the shore power would recharge my starting batteries. I know this because, of course, the boat would start but I'm not sure it was charging the house batteries. If I would leave the refrigerator on the batteries soon be died in spite of the solar panel and shore power working hard to recharge. The inverter was on and showed a good signal. I am not sure what the DC inverter switch does but I believe it allows certain items like the Fridge to toggle back and forth from AC to DC as needed. Once I would turn on the fridge the starting batteries would soon be dead. If I would have turned off the DC Inverter switch would the fridge have switched to the house batteries.
I have the impression that my problem with the dead batteries lies somewhere with how I'm turning the wrong switches on and off or the Fridge being bad or the house batteries being bad.
I'm land bound until I know I am doing the right thing. Dead batteries are too scary to "chance it".
The surveyor told me when he surveyed the boat that, although the batteries were performing well, I should replace them as soon as practical. So I guess there is a chance that one or both of the house batteries are dead but I don't know how to tell.
I don't have any handheld meters to use for diagnosing these things and could benefit from some suggestions.
Penny for your thoughts... |
Tom Hruby
C-Dory Year: 2024
Vessel Name: WATT NOW
Photos: WATT NOW
Posted: Tue Jul 08, 2025 3:45 pm Post subject: |
Don,
Here are some suggestions for trouble shooting.
1. Get a DC clamp meter that measures DC current without unhooking any cables. These run about $50. Make sure it is for DC not AC.
2. With everything turned off, check to see if there are any currents leaving the batteries. This will confirm if you have any slow leakage in your system.
3. Turn on your fridge and measure the current to see if the fridge is the problem (internal short that is draining the battery). Then determine which battery (house or starting or both) is powering the fridge by putting the clamp on the (+) wire leaving the battery.
4. Turn your different switches on and off to document how the power is moving in the boat.
5. You can also use the meter to document how the system is charged.
Hope this helps. |
Joined: 02 Nov 2003 Posts: 21549 City/Region: Pensacola
Yes, first but a digital volt ohm meter. I like the Klien CL 800 beause it does AC and DC up to 600 amps. It has maximum reading hold, but does not do true inrush current. This is more for the advanced boatowner, or some professonals. However it is $130 and has far more features than you will probably ever use. The best are Fluke. They are even more expensive.
Any cheap Home Depot or Lowes meter will work for you. General is one brand I have, (about 6 various meters) and then a collection of analog, incuding the one my dad used the in design and testing of San Onefre Nucular station. (and a lot of other major hydro and steam projects for Edison International)
Klein MM325 has most functions and is $35, or $40 for a Kein polarity teste, AC live circuit tester--over all probably the best deal...These only measure 10 amps of DC power (there are ways to measure more, but beyond what you need to know. Be certain that any meter has a 10 amp separate plug in; you may need to use that later as you gain expertise. I feel every boat under way needs to have a good ditial multimeter in its tool kit.
how to use a multimeter book
J _________________ Bob Austin
Tom Hruby
C-Dory Year: 2024
Photos: WATT NOW
Posted: Tue Jul 08, 2025 3:52 pm Post subject: |
More thoughts:
The DC amp meter will also usually have a volt meter. Measure the voltage of your battery during use. If the voltage drops significantly, it is your battery that is the problem. When I was using lead acid batteries I also had a resistance battery tester I got at an auto parts store (or Harbor Freight). The smaller units put a 50 -100 A current across the battery and will tell you if the battery is bad (too high a voltage drop). |
Joined: 27 Oct 2012 Posts: 3606 City/Region: SW Michigan
Posted: Tue Jul 08, 2025 5:58 pm Post subject: Re: Charging issues |
Donald Tyson wrote: | Took a shakedown cruise in the Chesapeake over the weekend and enjoyed the sunshine and warm weather. I hope you all enjoy your holiday weekend as well.
Does your boat have a battery charger or is the inverter also a charger? On my boat (with a charger) the batteries will charge from shore power even if the battery switch is off as long as the battery charger is on. If you have an inverter charger, then the battery switch needs to be on. Having a 1/2/all/off switch allows you to select only one battery (1 or 2) to run the house loads, leaving one battery in reserve for starting the engine. |
Donald Tyson
Photos: Thistle
Posted: Tue Jul 08, 2025 6:02 pm Post subject: |
Tom did you mean DC Amp meter or did you mean Clamp meter.
Dr.Bob, I downloaded the book. I'm picking up a 325 Kline soon.
SSobol, I have two batteries for starting and two batteries for the house.
All,
Tomorrow I will clean out the boat for access and examine exactly what I do have. |
gulfcoast john
Joined: 14 Dec 2012 Posts: 1056 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
Posted: Wed Jul 09, 2025 8:23 am Post subject: |
Hi Don,
Your AC/DC fridge will automatically run on AC power when that is available, and automatically switch over to run on 12v DC from your battery when no AC power is feeding it. You should find a circuit breaker for the fridge on your AC distribution panel, and a 10A fuse for the fridge on your DC fuse block (likely under the helm). If it’s not labelled, open the fridge door with the AC breaker off; the fridge light will stay on running on your battery. Start pulling unlabelled fuses; when the fridge light goes out, you have discovered the fridge 12v fuse. Label that on the fuse box cover.
To over simplify (which Bob rightly critiques me for), the power hog fridge compressor runs on DC. An internal module converts incoming AC current to DC, then feeds it to the Danfoss compressor. Converting the AC to DC wastes power, but who cares, the AC input is inexhaustible.
Your inverter converts precious DC power to AC, but VERY inefficiently…20% of the 12v output is wasted or turned into heat in that process.
SO, when you switch the battery selector to ALL with your inverter ON, you are sucking limited and precious DC amps out of your batteries, then wastefully converting those amps into AC amps, then feeding it to your automatic AC/DC fridge, which wastefully converts them back into DC amps to feed the hungry Danfoss DC compressor.
Also, true START batteries are engineered to provide a huge glob of amps for a few seconds to an engine starter motor. It’s such a huge glob that it’s the only circuit on a boat that does not even have a circuit breaker or fuse and still meet code (OK, code allows the bilge pump circuits to not require protection, but all my 13 trailer boats were wired with protection). Your START batteries will die early if asked to feed the DC Danfoss compressor for hours on end.
The batteries will have a mfg date code on them somewhere. Your surveyor found it. Average quality lead acid batteries reliability tends to degrade by four years old (from birth, not from purchase date). In your case, I contend that replacing them with flooded lead acid is a reasonable path if weight/size is not an issue. The 1860 technology is well proven, and a group 31 on sale runs $120 each. I previously favored Odessy and Northstar AGM, but after six years, with the Northstars still load testing fine, I replaced them when planning a Georgian Bay trip. They are not cheap.
https://www.interlightus.com/products/northstar-nsb-agm31.html?msclkid=fde12280f2ca176648724aeebd15f581&utm_source=bing&utm_medium=cpc&utm_campaign=PMax%20-%20Group%20NA%20%26%20ROAS%20%3C%205&utm_term=2325260935156096&utm_content=Asset%20group%201
You’ll be closer to civilization for the first few years. We are tucked into a remote cove on the UP on Lake Michigan (see Cat O’ Mine on NEBO). I understand the technology and have no fear of an inaccessible microprocessor in a lithium battery causing a ‘dark ship’ event here.
I suggest that four 12v batteries on a CD22 may be excessive. I’d suggest two FLA on sale group 31 deep cycle, if you have the room, one for starting the engines that meets ALL the specs in the engine manual, the other as House. Start each engine separately to reduce the load. Invest your savings in a Victron 702 or Bob’s equivalent battery monitor and maybe a solar panel. Then you can combine them (ALL) at anchor and monitor to not discharge over 50%. Swap the House and Start positions annually, Start battery leads a too easy life. I’ll convert to Lithium House when a true drop-in replacement with a ten year warranty is available from a company that has been in existence for ten full years.
Don’t fret, you’ll figure it all out like the rest of us. PM or call if my assumptions about your fridge model or start batteries are wrong. Safe travels!
2010 Tom Cat 255, Cat O' Mine
2024 Yamaha F150xsa x2 |
Tom Hruby
C-Dory Year: 2024
Photos: WATT NOW
Posted: Wed Jul 09, 2025 3:31 pm Post subject: |
Hi Don,
There are two types of DC amp meters. The first runs all the power through a shunt that sends a signal to a dial separate from the shunt. These are permanent installations and are what power your amp meter in the battery or on your console. Also non-clamp multimeters, with a DC amp meter included, use this approach. You disconnect the wire and use the attached probes to complete the circuit. These are usually limited to 5-10 amps for very short periods of time (1 sec or less). The wires in the probes are usually 20 or 18 gauge and can't handle a 10A load.
The second type has a clamp that you clamp around the wire carrying the current and measures the AMPS using a hall effect sensor (ie. measures magnetic field created by the current). This allows you to measure current without disconnecting any wires.
A lot of clamp type multi-meters are listed as AC-DC but only measure AC current and DC voltage. You need to make sure your clamp meter also measures DC current. The other thing I have found important when tracing slow leaks is the sensitivity of the DC meter. Many of the less expensive ones do not list that value. I would suggest finding one that measures at least 50mA (0.05 A). I have had good luck with the "medium" priced meter from Harbor Freight or the ones from Klein. Fluke are the best but also pricey. |
Donald Tyson
Photos: Thistle
Posted: Wed Jul 09, 2025 8:35 pm Post subject: |
I feel empowered with all your comments.
John I'll definitely stay in my comfort zone and remain with lead acid batteries.
Tom, I didn't listen and will return the AC clamp meter tomorrow.
I think John nailed it with his explanations regarding the fridge but tomorrow I'll have the tools to prove it.
G'night! |
Donald Tyson
Photos: Thistle
Posted: Fri Jul 11, 2025 10:05 am Post subject: UPDATE |
I bought the HB Clamp meter. I guess it is either bad or I don't know how to use it. There is no content info on the screen no matter what I do and no matter what setting it is in. I guess that gets returned. However the probes work to get voltage displayed.
While I haven't taken anything apart yet the main starting battery seems to be an issue. It measures 6 V. The other starting battery measures 13.4. When I turn the battery switches to all both starting batteries go to 12.1.
Both house batteries are at 12.1 to 12.2. |
Donald Tyson
Photos: Thistle
Posted: Fri Jul 11, 2025 12:32 pm Post subject: Re: UPDATE |
Donald Tyson wrote: | I bought the HB Clamp meter. I guess it is either bad or I don't know how to use it. There is no content info on the screen no matter what I do and no matter what setting it is in. I guess that gets returned. However the probes work to get voltage displayed.
With both the inverter and the charger neither of their fans come on even though it is an unbearable Hot & humid day. furthermore the voltage on the inverter is stuck on 11.9V and 1 Amp. so it sounds to me that there is no juice getting to it. I'm betting a cord or circuit is bad somewhere in my shore power adapter.
I reached into the starboard battery cabinet and turned on the starting batteries and turned off the breaker. It did not affect the house batteries. I've checked the cords and they are full of juice. it just isn't getting back to the inverter I guess. Then someone, put all the electronics in the back of the galley cabinet. I can't reach it and can't fit my upper body in there. If these chargers are bad (Doubt it) I'll have to hire a shrimp to repair/replace them. But the shore power chord and bad starboard battery I can do myself.
This is just a start... |
Posted: Fri Jul 11, 2025 1:43 pm Post subject: |
For a beginning it shoulds is if several of your batteries are bad, if they are "fully charged". The resting voltage for a FLA battery is 12.7 Volts, for an AGM battery 12.8 volts. I consider 12.2 volts to be 50% discharged for a resting state: no charging or power draw for at least an hour, to avoid surface charge effect.
The battery which shows 13.6 volts must be on a battery charger when you measured voltage--that does not measure the true voltage of the battery. less than 12. 6 volts resting means a problem with that battery.
I am not familiar with and "HB Clamp meter"--stick with the proven brands, even though they may be more expensive...maybe even read up a bit on the different meters in either of the two books recommended. Start with a simple DC volt /10 amp separte plug in meter to start with. As you gain profiffiency with the digital meter, then it may be time to buy a second Klien or Fluke meter clamp on meter.
Unless you only have use for a limited amount work for a specific tool, buy from the best brands and quality tools. It will last a lifetime. Cheap Harbor Freight type of tools are fine for a limited use in some applications. I own a few. However most of my tools are Porter Cable, Craftsman, Milwalkee, Ryobi or DeWalt. Makita also has a few places in my inventory. I don't have Snap On or MAC, but I am not a professional mechanic...If I was, I would have those most likely. So there is a Middle grouns in quality. |
Donald Tyson
Photos: Thistle
Posted: Fri Jul 11, 2025 2:21 pm Post subject: |
I agree that this is not an appropriate voltage for a resting battery that has been on a charger for three days. The resting voltage for a FLA battery is 12.7 Volts, for an AGM battery 12.8 volts. I consider 12.2 volts to be 50% discharged for a resting state: no charging or power draw for at least an hour, to avoid surface charge effect.
It is on the solar panel and controler.
Roger that: Start with a simple DC volt /10 amp separte plug in meter to start with. As you gain profiffiency with the digital meter, then it may be time to buy a second Klien or Fluke meter clamp on meter.
Ryobi and Dewalt are my favorites for light power tools. Boat fans are all Ryobi's. Mechanic tools are often bought in cheap sets. I like Cobalt, Dewalt and craftsman but since I collect Fishing Reels I go to a lot of fleas and sometimes buy tools as well. , Milwalkee, Ryobi or DeWalt. Makita also has a few places in my inventory. I don't have Snap On or MAC, but I am not a professional mechanic...If I was, I would have those most likely. So there is a Middle grouns in quality.[/quote]
It bothers me that the fans are not on in the chargers and inverters. It bothers me that the meter on the inverter says 11.9. Shouldn't that be 13.4 or more? |
alainP
C-Dory Year: 2011
Vessel Name: deja la
Posted: Fri Jul 11, 2025 5:30 pm Post subject: |
What is the resting voltage of the battery (ies) your inverter is connected to? |
Posted: Fri Jul 11, 2025 7:14 pm Post subject: |
Hi Donald,
Hard for me to follow all the electrical talk, as each boat seems to have it's own system. And the only way to know anything for sure, is to know how the batteries are hooked up. IE, an electrical schematic showing how the batteries are wired to the charger, and how they are wired to the house items and any other things such as an inverter. But that being said, the first thing I would look for are fuses between the charger and the batteries. If wired properly, there should be a fuse on each lead at the charger, and another fuse at each battery. Also, I'm assuming when you place your battery switch to all, it is paralleling all your batteries together that are connected to the switch. Some chargers warn not to parallel the batteries that way when the charger is on, if the batteries each have a separate terminal at the charger. You mentioned shore power, but I assume the engine's alternator is also putting out a charge when it's running. Colby |
