More Seating Room for a CD 25
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sun Jun 03, 2007 9:59 pm    Post subject: More Seating Room for a CD 25 Reply with quote
A lot of people (OK, well a few...) have asked me about my seat mod which provides an alternate bottom seat cushion location 6 inches towards the aisle -- seats 4 people at the table more comfortably. This makes use of the cushion portion tucked under the dead area of the outside walk-around ridge. The trick is to fab some sort of retainer so when you stick the cushion out more into the aisle, it doesn't flip up at the other end when you sit on the now cantilevered portion sticking into the aisle.
I limited it to about 6 inches because any more begins to interfere with two people squeezing by in the aisle. I also extended (rebuilt) the table to be another 7 inches longer (cost for materials at Home Depot, $10).
Here is the seat in the original position:
Now in extended position:
Aisle view extended position:
There are 2 retaining pins per seat, fore and aft edges of each seat, this is a drywall screw inserted into the wood, then head cut off and rounded with a dremel cut-off wheel (sorry a little blurry):
Corresponding notch in starboard alignment pieces attached to seat cushion (I repositioned these):
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
Page generation time: 0.0239s (PHP: 56% - SQL: 44%) - SQL queries: 14 - GZIP disabled - Debug on
