Taking Apart The Wallas 95 DU
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents
primative
City/Region: Portland
Vessel Name: Primative
Photos: Primative
PostPosted: Thu Jan 03, 2008 11:32 pm    Post subject: Taking Apart The Wallas 95 DU Reply with quote
On remote and weekend trips alike, we depend on our Wallas to keep us warm and cook our food. While we also take a back-up backpacking stove and mini propane heater, we would rather be using the Wallas. We needed to get over our fear of some of the basic maintenance issues. Here is a record of our experience last winter learning to take apart our stove, hoping it will be useful to some of you.
Tom & René
TAKING APART THE WALLAS1.pdf
 Description:
Download
 Filename:  TAKING APART THE WALLAS1.pdf
 Filesize:  1.11 MB
 Downloaded:  3625 Time(s)
(Primative)
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Fri Jan 04, 2008 12:44 am    Post subject: Reply with quote
I am awestruck. What a magnificent job of technical documentation!
Surely you must do this professionally?
Doryman
M/V Lori Ann
Anacortes, WA
Ron on Meander
City/Region: Powell River
Vessel Name: Meander
Photos: Meander
PostPosted: Fri Jan 04, 2008 12:00 pm    Post subject: Reply with quote
Tom,
Wow! What a great job of documenting the servicing of the Wallas. I have taken mine apart a couple of times (two different stoves) and serviced them but have never taken the time to document what I did. Your document is amazing and will be a great service to others. Thank you very much for not only taking the time to do it, but for the superb way you have shared your knowledge.
Ron
PostPosted: Fri Jan 04, 2008 1:14 pm    Post subject: Reply with quote
Tom-
A terrific job on the Wallas service document!
Makes me want to buy a Wallas just to have it to tinker around with!
Joe. Thumbs Up Teeth
PostPosted: Fri Jan 04, 2008 1:28 pm    Post subject: Reply with quote
I agree, wonderful job. Needs to be printed out and included with each C dory which has a Wallas!
MOOSE
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Fri Jan 04, 2008 1:32 pm    Post subject: Reply with quote
This is truly one of the best, most informative posts I have ever read. Thank you so much for putting together this much needed document.
Al
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Fri Jan 04, 2008 4:08 pm    Post subject: Reply with quote
...and it's in English! That Finnish is a b.....
MartyP
Ted Osborne
City/Region: Des Moines, WA
C-Dory Model: 24 Tomcat
Vessel Name: Tabbycat
PostPosted: Sat Jan 05, 2008 2:35 pm    Post subject: Reply with quote
I gree with what everyone has said. What an awesome bit of documentation.
It would be great to have all the systems in our boats documented to this extent, particularly the electrical.
Ted & Donna
Not For Hire
City/Region: Cadillac, MI
Vessel Name: Not For Hire
Photos: Not For Hire
PostPosted: Sat Jan 05, 2008 2:40 pm    Post subject: Reply with quote
Tom and Rene,
Thank you for this awesome post.
Regards,
Mark
Mark S
Cadillac, Michigan
primative
Photos: Primative
PostPosted: Sat Jan 05, 2008 3:54 pm    Post subject: Reply with quote
Thanks for your kind responses. It's really gratifying as we've burned ourselves out on it a time or two. Or three.
We have absolutely no technical writing background, limited mechanical experience and this is our first manual. We're just following in the footsteps of you who've already offered so much information on this site. We wanted to "pay it forward", and we loved and feared our Wallas stove. After reading "ZEN and the Art of Motorcycle Maintenance, Tom, with his tenacious and perfectionistic rigging abilities, found this writing to be a good way of coping with his Wallas frustration. After many years of doing graphics and design as artist for our local paper, The Oregonian, Rene has picked up a few editing skills. We've had many discussions in choosing the best language -- after all, we hope to make sense of it ourselves the next time we disassemble.
Apologies for it's dearth of humor!
In addition to the tools list, Tom keeps baling wire, suction cups, velcro and electrical tape on board at all times. He wants to add that, in case of emergency, he maintains the right to blow a hole through the ceiling with his 12-gauge to insert a wood stove pipe as his brother in Alaska recommends. Rene suggests she may not be accompanying him on many voyages in that event.
- Tom & René
PostPosted: Sun Apr 20, 2008 12:12 pm    Post subject: Reply with quote
Tom, this is a very well done document, and what this document absolutely convinces me is that there is no way in HELL that I could take the Wallas apart, clean a glow plug or anything. Every direction is a disaster waiting to happen for me. But thanks for putting this together!
Our Wallas went bad the last time out - cooked lunch just fine, next time we fired it up, light was on for a few seconds, and then the 2 amp fuse on the circuit board blew. I have checked all the connections that I can see how to check, and tried it three more times - it blows the fuse each time. Now it is time for Patty to take it in to Scan Marine I guess.
All I want to do is take this SOB out so Patty can take it in, and it seems I can't even manage that. This is the lug nut redux. Two questions for starters:
1 - The GD green connector on the circuit board from the switch won't budge. Whatever pull I exert just flexes the circuit board without loosening the connector. I really can't even get my fingers in there, so I decided to try to disconnect the adjacent connectors - they won't budge either. Is there a release tab on the connector or something? I don't have real good vision to start with, but upside down in the recesses of the galley cabinet, it is even worse. Do you use some kind of a tool? Tom says "wiggle it side to side" - there just plain ain't no wiggle in this puppy . But for starters I have to get it out, don't I? Hope I can do that without destroying the ciruit board, any suggestions would be welcomed.
2 - Tom says to take the unit up through the countertop with the fuel line attached. Is there any reason for this? This would take four hands. Can the fuel line be easily detached at the Wallas end? I see where it goes into the unit, but again, I don't want to start yanking on it with brute force. How is it attached? I do I get it out?
Thanks for any suggestions anyone has. This whole thing is completely non-obvious to me...
dotnmarty
Photos: Lizzie
PostPosted: Sun Apr 20, 2008 12:28 pm    Post subject: Reply with quote
Boy do I know that feeling. I think I'll have that inscribed on my tombstone.
PostPosted: Sun Apr 20, 2008 12:32 pm    Post subject: Reply with quote
1) That green connector plug is a baffler alright. You gotta pull on the wires and not the green plastic deal. Rock it back and forth lengthwise while pulling on the wires and she slips off easy. No lock tabs. You'll see when you get it unplugged why you can't pull it like it looks likes it should be pulled.
2) Use two little bitty wrenches for the fuel line. One to hold the elbow fitting in the pump and one to turn the nut on the tube. If it is easier to unhook it before you take the stove out ten that's the best way. You do want to unhook the stove end of the tube.
Ron on Meander
Photos: Meander
PostPosted: Sun Apr 20, 2008 12:42 pm    Post subject: Reply with quote
Pat,
In the past I've found it somewhat easier to just disconnect the exhaust pipe, undo the screws from the top mounting bracket, make sure there is enough slack in the control module wire and the fuel line, than lift the wallas out and disconnect the wiring and fuel line once I have the stove up on the counter. I too am somewhat challenged in seeing the connections and working upside down under the counter. Once you have taken the stove out a few times, you'll get it down to a science. Laughing
Ron
And to Tom and Rene for creating that service manual. What a great job! Beer Cigar
PostPosted: Sun Apr 20, 2008 1:13 pm    Post subject: Reply with quote
Well, the ##!@@# Wallas is out, I see what you mean about the connector - I see what I had been trying to do was to rip the socket off the circuit board. Pulling on the wires is so contrary to everything anybody has ever told me about connectors. When it was out, trying to detach the fuel line was a nightmare, the part that screws onto the "L" was so tight that I thought I was going to break it all apart, but it finally popped loose with no apparent damage. I would throw this sucker overboard but Patty won't let me.
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents All times are GMT - 5 Hours
Page generation time: 0.0536s (PHP: 71% - SQL: 29%) - SQL queries: 30 - GZIP disabled - Debug on
