Fogged windows.
flapbreaker
City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
PostPosted: Sun Jan 06, 2008 1:03 pm    Post subject: Fogged windows. Reply with quote
Can anyone recommend a good anti-fog product for windows (non-pc variety). Usually mine will fog in the morning when the curtains are up. I remember someone at the boat show selling some expensive stuff but is there an off the shelf product that works GOOD?
PostPosted: Sun Jan 06, 2008 1:18 pm    Post subject: Reply with quote
I've used the Rain-X inside stuff and it works pretty well. But, with all the humidity inside a closed boat, it's not enough to keep the windows clear without some additional ventilation. It's certainly not as effective on the inside as the regular Rain-X is on the outside.
http://captnjim.blogspot.com/
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Jan 06, 2008 1:21 pm    Post subject: Re: Fogged windows. Reply with quote
I use regular Rain-X inside & out Mr. Green Beer
depperson
City/Region: Juneau
Vessel Name: Mary Ann
Photos: Mary Ann
PostPosted: Mon Jan 07, 2008 12:54 am    Post subject: Reply with quote
I use liquid dish detergent, add a few drops to a paper towel,and rub on with a circular motion. It leaves a temp film but quickly disappears, it will last a couple hours at a time.
DeanO
smittypaddler
City/Region: Neenah, Wisconsin
Vessel Name: Na Waqa
PostPosted: Mon Jan 07, 2008 12:57 am    Post subject: Dish detergent Reply with quote
I got this tip on C-Brats, and it works great! Just put a little dish soap on a rag and wipe the inside of your windows. You don't need much, and it doesn't blur your view at all. Oh my, was it nice to learn this trick, after spending hours wiping down the windows every five minutes. I used to drive with a towel on one hand on cold wet days.
john schuler
City/Region: Missoula, Montana
Vessel Name: Clara (sold)
PostPosted: Mon Jan 07, 2008 7:28 am    Post subject: no fog Reply with quote
I keep some windows open at night to reduce resipratory water vapor. If its
to cool run the wallas. This keeps the windows clear and the cabin warm.
CoolSmile john CoolSmile
bshillam
City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
PostPosted: Mon Jan 07, 2008 12:02 pm    Post subject: Fan helps too Reply with quote
I purchased one of the 12v plug in fans it also runs off battery power too. Great thing as it keeps several windows clear. Up here with the cooler weather and moisture we keep the Wallas and fans moving anytime we are. Does help in keeping it dryer in the cabin. I too use the rain x anti-fog too. Between those thing the windows stay pretty dry and visible throughout our journeys. Wink
Dene
City/Region: Kalama
Vessel Name: Fear Naut & Terra-Sea-Ta
PostPosted: Mon Jan 07, 2008 3:40 pm    Post subject: Re: Fan helps too Reply with quote
Which fan and where did you get it? I need one soon. Meanwhile, I'm going to try the dishwashing soap trick.
Thanks!
-Greg
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Mon Jan 07, 2008 8:47 pm    Post subject: Ecofan Reply with quote
Another way to defog is to use an Ecofan on the Wallas when you are at anchor or at the dock. It takes a bit, but there is no current draw on the battery except for the Wallas. We use ours in the boat and the wood stove at home. Ours came from Cabella's.
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Mon Jan 07, 2008 10:26 pm    Post subject: Fan Reply with quote
It's made by camframo I bought it through alwaysbright.com or something along that nature. I've been very happy with it so far. I know boatersworld also sells the exact same thing but I think they put their own name on it. I've also read others have the same fan and like it cause it operates on low for 300 hours off four Ds.
PostPosted: Tue Jan 08, 2008 12:04 am    Post subject: Reply with quote
With that subject line, I was really hoping for a more interesting post.....
But, alas it's not to be. Anyway, I agree with Jim - rainx inside and out and some ventilation will help.
mwilson
City/Region: missoula
State or Province: MT
Vessel Name: STORMY
PostPosted: Tue Jan 08, 2008 12:28 am    Post subject: water spots Reply with quote
Anyone have any tips for removing water spots on the glass? I've tried everything I can think of. michael
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Tue Jan 08, 2008 1:11 am    Post subject: water spots Reply with quote
I use Ducky or white vinegar for water spots.
Jody Kidd
KE7WNG
Northern, Utah
PostPosted: Tue Jan 08, 2008 3:21 am    Post subject: Re: water spots Reply with quote
If the waterspots are so bad that the vinegar won't dissolve them, get a can of Bartender's Friend (like Comet or Ajax, only milder with a softer abrasive) and let the oxalic acid and the mild abrasive clean off the hard water deposits. Don't scrub too hard, let the acid dissolve the deposits, using the abrasive as a helper. Rinse it throughly off the boat. The acid will attack the wax and the abrasive will scratch the gel coat if it's not flushed off fully.
The Bartender's Friend can also be used to bleach out stains in the gel coat and non-skid areas, but you must rinse thoroughly afterward. The gel coat will have to be re-waxed.
This cleaner will also clean up and polish stainless steel nicely. It's a bit rough to use on aluminum, though.
The oxalic acid is a good "bleach" and rust remover. It contains a lot of relatively free oxygen radicals that attack stains, rust, and corrosion.
Use with care and do test patches first to determine suitability.
Joe. Thumbs Up Teeth
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Tue Jan 08, 2008 12:08 pm    Post subject: Here's the link Reply with quote
Sorry I it's Caframo here's the link to follow, great prices
http://www.alwaysbrilliant.com/aa/aspx-products/1-488/2-35974/3-1/bb/battery-powered_mini_fan,smallest_fan_we_sell.htm
Page generation time: 0.0444s (PHP: 63% - SQL: 37%) - SQL queries: 32 - GZIP disabled - Debug on
