Sealing around the heater exhaust thruhull
Ron on Meander
City/Region: Powell River
Vessel Name: Meander
Photos: Meander
PostPosted: Sat Apr 19, 2008 3:24 pm    Post subject: Sealing around the heater exhaust thruhull Reply with quote
I'm installing a Wallas 1800 furnace in my boat and I'm wondering what others used to seal around the exhaust thruhull on their installs. I've had people tell me that because the thru hull is a duplex, (cold air return out side the centre exhaust), I could just use 3m 4200 as a sealant because the temp next to the hull doesn't get all that hot, just the centre exhaust pipe gets hot and its inside the outer sleeve of the cold air return.
Any thoughts and suggestions appreciated.
Thanks
Ron
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sat Apr 19, 2008 4:09 pm    Post subject: Reply with quote
Can't help you on the question Ron, but I would be very interested to see some pictures of the installation when you are complete. This is something I could be interested in.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
PostPosted: Sat Apr 19, 2008 5:34 pm    Post subject: Reply with quote
Ron-
Most folks just use a High Temperature RTV silicone rubber compound available at your local auto parts, RV, or marine dealer. They're designed specifically for that type of application.
I don't know if 5200/4200 and the like are compatible with high temperatures or not. I don't think they'll "fill" the space around the tube as well as the RTV.
PostPosted: Sat Apr 19, 2008 6:42 pm    Post subject: Reply with quote
Agree with Joe. I installed a 45,000 BTU diesel hydronics system on the Cal 46 we used to cruise Alaska for 3 years. I used the RTV silicone, and had no problems. The hull never got hot. The small Wallas unit should not be a probelm.--just don't put a fender or other item over the exhaust!
Ron on Meander
Photos: Meander
PostPosted: Sat Apr 19, 2008 6:54 pm    Post subject: Reply with quote
Joe & Bob,
Thanks for the tip about the RTV silicone. I just ran out to the local NAPA and picked up a tube.
David,
For sure I'll post pictures and you are very welcome to do a personal inspection at the Friday Harbor CBGT in May.
Thanks again for the help.
Ron\
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sat Apr 19, 2008 11:40 pm    Post subject: Re: Sealing around the heater exhaust thruhull Reply with quote
Thanks
Ron
I used 5200 & the cork gasket that came with the thrugh hull fitting on my stove, after 60 hrs on the stove all is well Mr. Green Beer
Catch 22
City/Region: Lynnwood
Vessel Name: Catch 22
Photos: Catch 22
PostPosted: Mon May 19, 2008 12:04 am    Post subject: wallas stoves Reply with quote
im starting to design the interior of my boat, it pretty much has nothing in it right now, im gonna be putting in a wallas stove eventually but i want to build it into the design now, im wondering if anyone has pictures if the whole system, the tank, hoses, exaust, so i can get an idea of a good place for it, and how much space it needs, any info, dimentions or pics would be great, thanks...
Kevin Richards - Catch 22
tsturm
Photos: JMR-TOO
PostPosted: Mon May 19, 2008 9:48 am    Post subject: Re: wallas stoves Reply with quote
Here is how I did it!! Mr. Green Beer
Catch 22
Photos: Catch 22
PostPosted: Mon May 19, 2008 9:30 pm    Post subject: Reply with quote
is that a one gallon tank, how long does that last, anyone know the length and width of the stove top...thanks for the pic...
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Tue May 20, 2008 12:54 am    Post subject: Reply with quote
Catch 22, I installed a Wallas 1300 Heater, should be similar enough for comparison. Go to my album, I have photos of the installation for a CD25. There are other installs on CD22's. As far as how long does a gallon last, I believe my 1300 uses about 4 oz per hour and if I remember correctly, they estimated about 40 hrs per tank (5 quarts).
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
tsturm
Photos: JMR-TOO
PostPosted: Tue May 20, 2008 1:49 am    Post subject: Reply with quote
That is the 10L tank 2.6gal?? Mr. Green Beer Beer
The cut out is APROX. 17"X19" (not exact, from my CRS memory)for the stove top Mr. Green Beer
Catch 22
Photos: Catch 22
PostPosted: Wed May 21, 2008 5:44 pm    Post subject: Reply with quote
thanks folks
Page generation time: 0.0466s (PHP: 67% - SQL: 33%) - SQL queries: 29 - GZIP disabled - Debug on
