Drybunk
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Wed Jul 16, 2008 1:33 am    Post subject: Drybunk Reply with quote
A sailor riend advised me to put some Drybunk under my berth cushion.
A search for "Drybunk" returns no hits, so apparently it has not been discussed here. Any thoughts on the subject?
Doryman
M/V Lori Ann
Anacortes, WA
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Wed Jul 16, 2008 9:22 am    Post subject: Reply with quote
Warren, If you click on the blue highlighted "DryBunk", it will take you to West Marine's catalog page with the dry bunk liner for sale!!! Amazing.
Ask and ye shall receive!
PostPosted: Wed Jul 16, 2008 9:42 am    Post subject: Reply with quote
Methinks the link fairy was at work last night...did you leave a quarter under your pillow? Laughing
PostPosted: Wed Jul 16, 2008 12:21 pm    Post subject: Reply with quote
what he is asking is have WE talked about it here. He searched HERE and found no talk about it and wanted to know what WE thought of it. come on guys follow the ball. Wink
Doryman
Photos: Lori Ann
PostPosted: Wed Jul 16, 2008 12:58 pm    Post subject: Reply with quote
Laughing Laughing Thanks, Tom.
Subsequently, I learned of HyperVent, another approach to the same issue.
I do know there was prior discussion here about keeping condensation off the cabin berth walls, so thought this might be part of the solution. I have found some minor mold growing on the underside of my berth cushion and want to prevent it in the future, if possible.
primative
City/Region: Portland
Vessel Name: Primative
Photos: Primative
PostPosted: Sun Mar 22, 2009 4:19 pm    Post subject: Reply with quote
For anyone actually using drybunk, do you like it? I've taken our mattress out with a plan to shave the foam in half, replace 2 inches with memory foam and stuff it back in the case. I see the berth foam has a slight discoloration, probably due to moisture. Also, Tom is adding storage hatches in the berth that will stick up a half inch into the mattress space and I'm thinking a 3/4 inch layer of drybunk would even things out, using a thinner material over the hatches. Tom is concerned about losing headroom in the berth. Also, the drybunk may make hatch access more difficult.
- Rene
(Primative)
Doryman
Photos: Lori Ann
PostPosted: Sun Mar 22, 2009 8:53 pm    Post subject: Reply with quote
I have used DryBunk with good results. It soaks up the moisture and mold, leaving the bottom of my cushions clean (so far.) It is very thin and does not affect the usability of the berth. I think you may be thinking of another product that is about a half-inch thick and creates a space for air to circulate between the cushions and the berth. Unfortunately I cannot remember the trade name of this product right now. Maybe someone else will be able to supply it.
On edit: Hypervent (link is above) is what I was trying to think of.
PostPosted: Sun Mar 22, 2009 10:07 pm    Post subject: Reply with quote
DryMesh is a product which is an open weave and goes under the bunk. I did use it and found it worked well. I did not have as good an experience with DryBunk in the Rinker 270--and the "cave" bunk. I got mildew on the Drybunk.
I then switched over to keeping the bunk raised if I was not using it--and running a dehumidifier and heater (winter) or airconditioner (summer) and problem resolved.
I have not had a problem with the Tom Cat or C Dory 25--I think that I had more moisture in the cabin with the Rinker.
Doryman
Photos: Lori Ann
PostPosted: Sun Mar 22, 2009 10:29 pm    Post subject: Reply with quote
I would say that the DryBunk worked as it should -- it kept the mildew off your cushions and on the disposable, replaceable DryBunk. However, that said, I think your solution (Hypermesh, raising the bunk, etc.) is better than DryBunk.
primative
Photos: Primative
PostPosted: Mon Mar 23, 2009 12:29 pm    Post subject: Reply with quote
Ahhh, thanks! That helps a lot. I was confusing drybunk with hypervent, it's the hypervent I want, or something like it, though drybunk might be a good spacer over the hatches.
Drymesh looks similar to hypervent, but I only found it available in the UK.
Any good local sources?
Looking online for hypervent, www.sailboatowners.com says shipping is $4. per foot (which would be at least $40)! The company site www.hyperventmarine.com couldn't calculate the shipping. So I called. The company is up in Marysville WA, and I spoke with Rex, who didn't know of a Portland outlet but said I could email my order directly to him and he would find a reasonable shipping rate.
Our berth stays fairly dry as is, but you can't be too dry in a marine environment.
- rene
Nan-C
City/Region: Oakland
Vessel Name: Nan-C
Photos: Nan-C
PostPosted: Mon Mar 23, 2009 1:58 pm    Post subject: Reply with quote
Once I recognized how wet it was getting under the v-berth cushions, I installed Aquamat tiles to create an air space under the cushions. It does not prevent condensation, but it keeps the cushions dry and allows the hard surface to dry without mildew forming. We are happy with the results.
Regards to all,
Greg
Doryman
Photos: Lori Ann
PostPosted: Mon Mar 23, 2009 10:09 pm    Post subject: Reply with quote
Greg, what is this material and where do you buy it?
Dene
City/Region: Kalama
Vessel Name: Fear Naut & Terra-Sea-Ta
PostPosted: Mon Mar 23, 2009 10:42 pm    Post subject: Reply with quote
My liveaboard buddy swears by it. I've used Bob's method, keeping a humidfiers mounted aboved the berth, on a cutting board. The other is on in the main cabin. No problems with either boat.
-Greg
Doryman
Photos: Lori Ann
PostPosted: Mon Mar 23, 2009 10:53 pm    Post subject: Reply with quote
I have seen Hypervent advertised in the local WA free boating publications.
Nan-C
Vessel Name: Nan-C
Photos: Nan-C
PostPosted: Mon Mar 23, 2009 11:03 pm    Post subject: Reply with quote
Warren -- Aquamat is a 1'x1' tile like the Dri-Dek West Marine sells. I picked it up at Boaters' World just because I happened to see it in the store when we were in Key Largo experiencing a lot of condensation. I think the Dri-Dek is a little heavier and possibly better quality. The Aquamat is very flexible so I was able to bend it right of the side of the v-berth to the height of the cushions and bedding. I assume the Dri-Dek is similar in flexibility -- but I'm not sure.
Greg
Page generation time: 0.0467s (PHP: 66% - SQL: 34%) - SQL queries: 32 - GZIP disabled - Debug on
