PDF Manual for Wallas Stove
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Thu Aug 28, 2008 1:50 am    Post subject: PDF Manual for Wallas Stove Reply with quote
Here is the manufactures PDF manual foe the 85DU Wallas Stove
wallas_85DP_85DP.pdf
 Description:
Download
 Filename:  wallas_85DP_85DP.pdf
 Filesize:  208.28 KB
 Downloaded:  2551 Time(s)
Jody Kidd
KE7WNG
Northern, Utah
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Thu Aug 28, 2008 9:57 am    Post subject: Reply with quote
Jody,
Thanks so much for posting the Wallas pdf file. I have never seen an instruction manual either.
As for anecdotal evidence, I've had no problems running mine on Kleen Heat for almost 2 years now other than to make sure fuel is up into the feed tube at startup after long disuse.
I was not aware that the yellow and red flashing rates were indicative of what problems are preventing normal use.
macmac
PostPosted: Tue Sep 04, 2012 2:06 pm    Post subject: Wallas 85DU270 Manual Reply with quote
Attached you will find the manual we publish for this product in the USA.
Doug at Scan
888-606-6665
Wallas 85 manual Dec 2011.pdf
 Description:
Download
 Filename:  Wallas 85 manual Dec 2011.pdf
 Filesize:  2.39 MB
 Downloaded:  2976 Time(s)
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents All times are GMT - 5 Hours
Page generation time: 0.038s (PHP: 62% - SQL: 38%) - SQL queries: 18 - GZIP disabled - Debug on
