1984 22' Angler in WA $14k
json
Sep 5, 2025
1
  • 2016 90 hp Yamaha 4 Stroke Outboard 25" shaft with 460 hours. Just changed the motor oil and filter
  • 2018 10 hp Yamaha 4 Stroke Outboard
  • Motors run great
  • Sanded to hull and new bottom paint this summer with Seahawk Cukote
  • Diesel/12V cabin heater
  • Depth sounder/GPS
  • VHF radio
  • wiring for pot puller
  • heavy duty welded aluminum plate on transom
  • Double axle Calkins trailer. Semi bunk semi roller. Trailer looks pretty rough but wheel bearings are greased and it tows down I-5 like a champ without wheels heating up.
  • Could use new window seals, and some epoxy work on splash well where previous owners had mounted fuel filters, battery hold downs, etc.
  • Topside paint is starting to peel off so isn't going to win any beauty contests.
  • Great way to get into an affordable 22' C-dory and out on the water.
  • Boat goes back and forth between Ferndale, WA and the San Juan Islands. Call with questions ‪(360) 322-4710‬
