Dora~Jean
Joined: 09 Mar 2004 Posts: 1518 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Sun Mar 23, 2008 4:03 pm Post subject: CD25 Shoulder Pads |
I can finally check off another item off my list. I finished upholstering and installing shoulder pads for the passengers. It was low on my list because it doesn't affect ME! But I felt sorry for my guests having to lean against the hard, fiberglass wall and tuck their shoulder under the window frame. Very comfy now.
I made an identical pad for the rear seat just for symmetry, plus doubles as a nice head/backrest for sitting sideways. They are shaped like that to accommodate the reversable front seat backrest. I used high density foam.
 _________________ Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
colobear
Photos: C-Cakes
Posted: Sun Mar 23, 2008 4:39 pm Post subject: |
Nicely done, one of those "why didn't I think of that" projects. _________________ Patti and Barry
formerly C-Cakes, now
rving around N. America |
C-batical
Vessel Name: C-Batical
Photos: C-Batical
Posted: Sun Mar 23, 2008 5:55 pm Post subject: |
What a super idea. I think I will add this to my 'to do' list.
Best regards, _________________ Rollie/C-Batical
Pinckney, MI |
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2783 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Sun Mar 23, 2008 7:19 pm Post subject: Shoulder Pads |
Hey, those look nice!! How did you fasten the cleats to the side of the cabin? My assumption is that they are glued in place somehow.
Steve |
Dora~Jean
Photos: Dora~Jean
Posted: Sun Mar 23, 2008 8:01 pm Post subject: |
3M 4200, very tough stuff.
First I drilled the screw holes from the cushion backplate (3/8" plywood) through the 2x2 supports on the bench for good alignment. Then slotted the plywood holes for the large SS screw heads to pass through and slide into place for final assembly. Then painted all pieces with primer and a good exterior paint (2 coats), except for the 2x2 side to be glued.
I cleaned the cabin wall surfaces with alcohol thoroughly. Put 1/8-1/4" beads on the 2x2 supports (bare wood) with them assembled to the cushion backplates (no cushions yet), then glued in place and held tight against the wall with my extension boat hook pressing from other side of cabin. When glue was dry, I removed the backplates leaving the screws in place.
I upholstered the cushions, inserted the foam (cut with an electric knife), then stretched and stapled onto the backplates. Had to loosen the screws about 1/2 turn to allow for the fabric thickness on the backside, then pushed into place and down for a tight fit. About 10-15 hours of designing and measuring, about 8 hours to do the work! |
SeaSpray
Joined: 12 Mar 2004 Posts: 1009 City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
Posted: Sun Mar 23, 2008 8:02 pm Post subject: |
Nice job! Did you do the sewing yourself? I am going to look at do this also.
Steve |
Dora~Jean
Photos: Dora~Jean
Posted: Sun Mar 23, 2008 8:14 pm Post subject: |
Seabran wrote:
Quote: | Nice job! Did you do the sewing yourself? I am going to look at do this also. |
Yes I did, thank you very much. I bought a Thompson Mini-Walking Foot industrial sewing machine new for $450 about 20 yrs ago, it has paid for itself many times over. I learned to upholster from my mom, she reupholstered antique couches, loveseats, divans and chairs to help out with the finances when I was growing up. I helped and watched everything I could. Didn't know I'd use it later in life, just interested.
...and the old coins and paraphenalia you'd find in some of the seat back bottoms, ohhhh if they could talk, and ohhhh if only I'd have kept them... |
Joined: 01 Mar 2005 Posts: 7485 City/Region: from island boy to desert dweller
Posted: Sun Mar 23, 2008 8:27 pm Post subject: |
Looks good and very functional - NICE!  |
Joined: 02 Nov 2003 Posts: 21505 City/Region: Pensacola
Posted: Sun Mar 23, 2008 8:48 pm Post subject: |
Great project--thanks for sharing! _________________ Bob Austin
IT-SEA-BIT-C Guest
Posted: Sun Mar 23, 2008 9:00 pm Post subject: |
PAT PAT PAT -that was a pat on the back for a job well done , nice pics too, looks nice & comfy, great job..... |
Al & Pat Parker
Vessel Name: Knot Home
Photos: Knot Home
Posted: Sun Mar 23, 2008 9:08 pm Post subject: |
Hi Steve,
Yes, we agree, very nice idea and job. we saw it this PM b4 all the comments, but had to head out for dinner, so didn't get a chance to send our kudos until now.
Ms Pat likes it, it'll be on our project list for Knot Home.
thanks, _________________ Al & Pat
C-D 25 "Knot Home"
Mainship Pilot 30 "Juust Right"
on the Neuse River at New Bern
W8UT
www.boatanchors.org/C-Dory25.htm
"there is nothing -absolutely nothing- half as much worth doing as simply messing about in boats."
(ratty to mole, Wind in the Willows) |
Sea Angel
Joined: 29 Dec 2003 Posts: 736 City/Region: Virginia Beach, VA
Photos: Sea Angel
Posted: Sun Mar 23, 2008 9:31 pm Post subject: |
Great touch,, Steve.
Now you've done it! I will have to figure out how to do this for Sea Angel.
Can you do this in blue???
Art _________________ Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4 |
Posted: Wed Jul 13, 2011 8:53 pm Post subject: |
One project done.
My version of the shoulder pads. Thanks to Steve (Dora Jean) for the idea and Camille (Berta's Boy) for the expert sewing.
I made the rear one rectangular to fill more of the space. Since the rear doesn't move like the front seat and since M likes to sit w/ her back there while we watch movies, it made sense.
2" thick, extra firm/dense foam, 1/2" ply, SS screws and 2X2s like Steve designed.
 _________________ "We can go over there...behind the 'little one'....."
Sarge
Vessel Name: Sea Badger
Photos: Gigi
Posted: Thu Jul 14, 2011 12:38 pm Post subject: |
The shoulder pads look great and professionally done. It's the kind of thing the factory might consider, even as an option. _________________ -Sarge
2001 2150 Bayliner, sold
2007 CD25, sold
2007 Harbercraft Kingfisher 2850, sold
2011 Stabicraft 2250SC, sold
2011 Eastern 18cc
Blog: http://theseabadger.wordpress.com |
