Fuel Gauge
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time
bobsboat
C-Dory Model: R-25 Tug
Photos: Bob's Boat
PostPosted: Tue Sep 30, 2008 11:58 pm    Post subject: Fuel Gauge Reply with quote
Has anyone had problems with their fuel gauge on a Ranger 25? I have only about half a tank of fuel left but the gauge needle sits on the full mark all of the time. It would be nice if the boat was making fuel but that is wishful thinking. Bob
Rick and Karen
City/Region: Honolulu
State or Province: HI
C-Dory Model: R-21 EC Tug
Vessel Name: Kolo Iki (Little Tug)
Photos: Kolo Iki
PostPosted: Wed Oct 01, 2008 12:46 am    Post subject: Fuel Gage Reply with quote
My R-21 EC fuel gage sits on empty no matter how much fuel is in the tank. I just sent an e-mail to the factory tonight to ask them if there is anything I can check. If anyone has any ideas, I am open to suggestions.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Wed Oct 01, 2008 7:15 am    Post subject: Sending unit Reply with quote
It sounds to me like a faulty or stuck fuel sending unit. How accessible are they on the Ranger's? Fuel sending unit's are notorious on every boat. I wish all boats were made to accept a wooden stick - that is the only reliable way I have ever known to keep track of fuel in a boat tank.
Captain Matt
Island Ranger
City/Region: Whidbey Island
Vessel Name: Island Ranger
Photos: Two Lucky Fish and Island Ranger
PostPosted: Wed Oct 01, 2008 10:44 am    Post subject: Reply with quote
Mine sits past full for a long time. By the time it moves to "F", I've burned 15 gallons. When it is at 3/4, I have about a half a tank. I've thought about trying to recalibrate, but never got around to it.
Mac
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Wed Oct 01, 2008 10:55 am    Post subject: Reply with quote
It has seemed to me, over the years, that most fuel tanks (mainly on vehicles) tend to stay on or near Full until almost half the tank is gone. At that point they dive for Empty so fast it makes your head spin.
Could it be the arc traveled by the float is more elliptical than circular? ...i.e., the sender reads out less vertically and more horizontally?
Even my Honda fuel gauges show full until almost half the tank is gone. I just use the "fuel used" log to see how many gallons I've used.
I don't think the problem is limited to the tugs.
garyk
City/Region: Ketchum
State or Province: ID
Vessel Name: AMIGO 11
Photos: Amigo II
PostPosted: Wed Oct 01, 2008 12:52 pm    Post subject: Fuel Gauges Reply with quote
The gauges in our Tomcat are quite predictable. They read on the low side while running and higher when sitting flat, ie. empty while at cruise and 1/4 or about 20 gal. on each side at no wake speed and the same at the fuel dock.
Gary
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Wed Oct 01, 2008 1:18 pm    Post subject: Reply with quote
My Tom Cat's Yamaha Command Link gas gauges are surprisingly accurate as well.
Doryman
M/V Lori Ann
Anacortes, WA
PostPosted: Wed Oct 01, 2008 1:40 pm    Post subject: Reply with quote
Our Honda fuel gauge didn't work right from day one... read 3/4 when full. When I asked the factory about it, they said it needed a different sender. Shortly afterwards, it completely died. We ran for months with no fuel gauge, just relied on estimated fuel burn per hour. We found that we could hit it pretty close (but carried a 5 gallon gas can as our "reserve"). We later had a fuel flow meter installed at a Honda dealer and mentioned the dead fuel gauge. He replaced the gauge itself under warranty (not the sender), and it has worked fine since... and now we have the gauge, the fuel flow meter, and I still calculate estimated fuel burn per hour. BTW, the Navman fuel flow meter has been very accurate.
When cruising, we always top off when fueling. When in our local water, I usually fill between 1/4 and 1/2 for day-tripping to keep the weight down.
PostPosted: Wed Oct 01, 2008 2:51 pm    Post subject: Reply with quote
Funny short story on fuel gages and what we are use too. If any of you have ever had an American car you know that even if you drain the gage to E you still have a few miles to go and get to a fuel station. We all know this and are use to it. My ford ranger would go another 50 mile after it got to E. A good buddy of mine Rob Hardy was a mechanic for Kia when they first came out. He worked for a new dealer in Sacramento ca. In the first month of operations they had 9 new Kia's get towed in because they "Just stopped running" After the first two having no other problem then being out of gas the sells department was told to warn all buys about how accurate the gas gage is. You see when a Kia says E they dam well mean it. These complaints finally lead Kia to re-design the gas gage to have a reserve after the gage hit E. That way us Americans will have a chance to get to the gas station before it really runs dry.
PostPosted: Wed Oct 01, 2008 2:56 pm    Post subject: Reply with quote
My Tom Cat guage is reasonably accurate (but not as accurate as my flow meters).
EDBRADY
City/Region: Stratford
State or Province: CT
Vessel Name: BRADY'S BUNCH
PostPosted: Wed Oct 01, 2008 5:13 pm    Post subject: Reply with quote
I to have had problems with the fuel gauge on my R25 Tug for almost 2 seasons. Around a month ago I got the nomeclature of the sending unit from Andrew Custis and ordered a replacement. I checked the new unit with a ohm meter before I reinstalled it. After installation I still had the same problem. I checked the old sender out and it was fine also. Sitting in my recliner at home one evening I held the sender in my hand and look at its profile. The float at its max height (which should be full tank) was at least two inches too low. I bent the wire rod so the float would extend higher and everything seems to be working now. The sender is a Rochester 8341-A7000 model.
Ed Brady R25, Hull #4
bobsboat
Photos: Bob's Boat
PostPosted: Wed Oct 01, 2008 7:06 pm    Post subject: Fuel Gauge Reply with quote
Thanks all of you for the posts. I filled the tank and it took 30 gallons [in a 75 gallon tank] so the gauge is not accurate. I now carry a plastic tube with some markings on it to show approximate fuel level in the tank and will watch my running hours more closely. bob b
SnugTug
City/Region: Ocean City
State or Province: NJ
Vessel Name: Snug Tug
PostPosted: Fri Oct 03, 2008 9:50 pm    Post subject: Gas Gauge on R-25 Reply with quote
When my gauge shows 3/4 full the tank is actually about half full. It's consistent and not a problem as long as you remember to compensate.
So where is the sending unit and how does one access it? If you can pull the unit and bend the float arm to correct the problem, I might give it a try. ??
Jon & Marilyn
Snug Tug
Ocean City, NJ
W3DVY
bobsboat
Photos: Bob's Boat
PostPosted: Fri Oct 10, 2008 11:26 pm    Post subject: fuel gauge Reply with quote
The fuel gauge sender is in the approximate centerline of the boat several inches forward of the engine room step. You can get the exact location from the factory. The two ways I have heard of to access the gauge sender are [1] cut a hole over the sender through the teak and holly sole and underlying fiberglass, then add an inspection plate or [2] cut a hole in the side of the cave at the fore / aft location of the sender [this does not leave much room above the tank to work with and I am told should not be done when the tank is full].
IdleUp
City/Region: Smith Mountain Lake
Vessel Name: Linda Sue
PostPosted: Sat Oct 11, 2008 8:05 pm    Post subject: Reply with quote
Not sure when they changed over but on the 09 Rangers with the Cummins engine, they installed a NMEA 0183 fuel pickup sender which registers the fuel levels and consumption on the Smartcraft display showing levels down to the gallon - when I wired the NMEA of my Garmin GPS to the Cummins Smartcraft it shows the range in miles depending on throttle position (consumption) and fule needed to each waypoint or route, plus total range at different throttle settings.
In addition, at the end of the day it shows MPG, fuel used, distance travel, average fuel consumption plus a host of other information.
Here's a link on Smartcraft and some displays:
http://www.cmdmarine.com/smartcraft/index.html
R/C Helicopter Pilot - 09 Ranger 150
My Other Hobbies:
www.rotory.com - www.bigpickup.com
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time All times are GMT - 5 Hours
Page generation time: 0.1153s (PHP: 32% - SQL: 68%) - SQL queries: 28 - GZIP disabled - Debug on
