Transceiver Alarm System for your boat
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time
PostPosted: Fri Nov 07, 2008 8:40 pm    Post subject: Reply with quote
No hiring out!
But do bring the gun along someimes for target clays.
Hope I haven't been too much of a diversion or off topic bandit here.
Some of us like to add some humor to spice up the technical and social disussions that we cycle through from time to time.
Cheers!...Teeth ...... PULL!... BANG!... Thumbs Up
eNORMous
City/Region: Beaufort
Vessel Name: Antibody
Photos: Antibody
PostPosted: Sat Nov 08, 2008 5:09 pm    Post subject: Reply with quote
I find Sea Wolf's humor entertaining and quite fitting at times Exclamation Shocked
I am what I am & that's all that I am & there ain't no more.
E Pluribus Normus
PLB Beacon ID: 2DCE5DE29CFFBFF
IdleUp
City/Region: Smith Mountain Lake
C-Dory Model: R-25 Tug
Vessel Name: Linda Sue
PostPosted: Sat Nov 08, 2008 6:17 pm    Post subject: Reply with quote
I'm shocked - I thought all you boat people were just normal people!
R/C Helicopter Pilot - 09 Ranger 150
My Other Hobbies:
www.rotory.com - www.bigpickup.com
PostPosted: Mon Nov 10, 2008 2:30 am    Post subject: Reply with quote
Normal is not one exact point on a scale, but a range from one side to the other that is inclusive of the point. Thumbs Up Hug Hug Thumbs Up
We are all normal in our own special way Laughing
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Mon Nov 10, 2008 11:02 am    Post subject: Reply with quote
I like that PEMCO ad that says "We're a lot like you..a little different."
MartyP
IdleUp
PostPosted: Thu Nov 13, 2008 10:20 am    Post subject: Reply with quote
Just an update on my alarm installation - the Scorpio alarm system has a circuit that flash's the lights on and off during arming and during a violation.
One of the "coolest" things about the Ranger is the fact they incorporated tail and marker lights in their hull. Yep, just plug in the harness in the anchor locker and your Ranger lights up for travel.
With this in mind, I wired my Scorpio alarm to the Ranger harness. You can find easy access right in the cockpit locker on the stern - port & starboard sides and behind the wall panel behind the helm. It's easy to spot the wires since Ranger used the same color code as the hitch. (brn-grn-yel).
Nice thing now should the alarm go off - the boat light's up. Another benefit should you be in the house or restaurant where you can't hear the alarm you can see the bright LED's flashing when you arm it or if there's a problem as well as warn others at night.
PostPosted: Wed Nov 19, 2008 12:51 am    Post subject: lites Reply with quote
Could be set up to turn on the cockpit light too?
IdleUp
PostPosted: Wed Mar 25, 2009 8:08 pm    Post subject: Reply with quote
You can hook the alarm to any 12 volt device however keep in mind that it blinks the lights on and off.
Post new topic   Reply to topic    The C-Brats Forum Index -> All Rangers, All The Time All times are GMT - 5 Hours
Page generation time: 0.0508s (PHP: 60% - SQL: 40%) - SQL queries: 21 - GZIP disabled - Debug on
