Towell Rack
Nunya
Photos: Nunya
PostPosted: Sun May 09, 2010 11:25 am    Post subject: Towell Rack Reply with quote
I've been wanting to mount a paper towell rack on the cabin wall and was wondering what everyone is using, since the wall is too thin for screws. 5200? Epoxy? Wondering how you remove it in the future if need be.
PostPosted: Sun May 09, 2010 11:58 am    Post subject: Reply with quote
I haven't gotten around to a PT holder but most I've seen have mounted them with 5200. This is how I mounted my wood strips for my curtain tracks.
PostPosted: Sun May 09, 2010 12:31 pm    Post subject: Reply with quote
The 4200 is designed especially to be much more removable than 5200, and can be softened with a special solvent or cut with a wire or high tech braided fishing line when needed, to remove.
Silicone will work, too, and like both the above, will have to have the wood blocks taped in place with masking tape until it sets up. It's less likely to harm the paint.
Epoxy works, too, but is a bit of overkill, and will take the interior paint off with it when removed.
PostPosted: Sun May 09, 2010 12:35 pm    Post subject: Reply with quote
We mounted a wood block with 5200, then screwed the towel holder to the block.
pcator
City/Region: Fletcher
Vessel Name: Donna Marie
Photos: Donna Marie
PostPosted: Sun May 09, 2010 12:55 pm    Post subject: Reply with quote
I used a two sided sticky putty like substance (can you see I don't remember the name of it} and just stuck the pt holder to it. That was 3 years ago and it hasn't fallen off yet. I also used it to hang a clock and have move it and it and the sticky stuff came right off.
Patrick
Nunya
Photos: Nunya
PostPosted: Sun May 09, 2010 1:19 pm    Post subject: Reply with quote
Wood blocks and 5200 it is........
Valkyrie
City/Region: Loudonville
State or Province: OH
Vessel Name: Valkyrie II
Photos: Valkyrie
PostPosted: Sun May 09, 2010 2:12 pm    Post subject: Reply with quote
We used one minute epoxy and a wood block.
Nick
"Valkyrie"
Dreamer
Photos: Dreamer
PostPosted: Sun May 09, 2010 7:11 pm    Post subject: Reply with quote
Nunya,
I have enough stuff on the walls already, so I mounted the PT rack on the inside of the cabinet door below the sink. Works great!
Dreamer- Sold 25 Feb. 2013
PostPosted: Sun May 09, 2010 7:15 pm    Post subject: Reply with quote
Paper towel holder is free standing (same on the 25 and the RV)--But for other items we mounted teak boards to the cabin wall. First scuff up the surface finish, then we used 5 minute epoxy and 5200, both. Works well--just consider the block is going to stay there--and that is what you want.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Sun May 09, 2010 8:06 pm    Post subject: Reply with quote
We did the same as Roger. Inside the door of the galley, LH side.
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Sun May 09, 2010 8:39 pm    Post subject: Reply with quote
On things I'm uncertain about the location I've used industrial strength velcro from Lowe's so if I decided I didn't like the location it could be relocated. It works very well on smooth gel coat surfaces.
marvin
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Sun May 09, 2010 9:16 pm    Post subject: Reply with quote
Nick's One Minute Epoxy is sure working overtime....
Mike Taylor
330-936-1030
Valkyrie
Photos: Valkyrie
PostPosted: Mon May 10, 2010 8:13 am    Post subject: Reply with quote
Mike,
Thanks for the picture, but everything seen in it is attached mechanically. The outmost pieces of teak use screws into the bulkhead, as does the Valkyrie nameplate with the clock and barometer. The bookrack is through-bolted. Only the paper towel rack is epoxied in place.
Regards,
Nick
"Valkyrie"
Papillon
Photos: Papillon
PostPosted: Mon May 10, 2010 9:47 am    Post subject: Reply with quote
Evil or Very Mad Dang it Nick, you sure know how to ruin a good story... Smile
Sea Angel
Photos: Sea Angel
PostPosted: Mon May 10, 2010 5:19 pm    Post subject: Reply with quote
NUNYA,
Like Roger; I too, have mounted my $1.50 PT holder on the inside of the
cabinet door under the sink with the two supplied screws. It is out of way
and readily available from the helm, if needed.
I also use the PT holder frame as a support point to hold the door open
with a bungie cord when I have to work under the sink area. This is
especially helpful when I have the CD25 on a work rack at the marina, for
the racks have an upward tilt up to allow water to drain out and off of the
boats.
Art
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
Page generation time: 0.0415s (PHP: 68% - SQL: 32%) - SQL queries: 28 - GZIP disabled - Debug on
