Quick Release for Table in 16Cruiser
Lono
City/Region: Kitchener
State or Province: ON
C-Dory Year: 2012
Vessel Name: CALADESI
PostPosted: Sat Jun 29, 2013 2:19 pm    Post subject: Quick Release for Table in 16Cruiser Reply with quote
Anyone have any ideas on a way to remove and install the table in the 16 quickly (without tools) I like it available but my wife prefers is out of the way when just crusiing around. Plus it gives more room to get in and out of the berth. Thanks Brian
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sat Jun 29, 2013 3:47 pm    Post subject: Reply with quote
Unless I'm missing something, simply loosen the three black screws a bit and lift the table off.
MartyP
Lono
C-Dory Year: 2012
PostPosted: Sat Jun 29, 2013 3:50 pm    Post subject: Reply with quote
That's what I was hoping for. Mine has two bolts with washers. New a wrench.
jack keifer
City/Region: Boise
State or Province: ID
Vessel Name: C-Squirt
Photos: C-Squirt
PostPosted: Tue Jul 02, 2013 8:43 pm    Post subject: 16 cruiser table issue Reply with quote
The C-Squirt also has the same setup with the studs and 3 hand knobs. We also wanted more distance between the back of the table and the seat back. So we moved the table forward and use only the 2 forward studs to secure the table. Then we wanted to improve the stability of the table. So I cut a 3/4 inch dowel to the exact length of the distance between the floor and the table and attached a rubber chair foot protector to each end and supported the outer edge of the table with it. Now we have more room between the back of the table and the seat back and a LOT more stability on the table, yet it is easy to remove. With this approach, your wife might not mind having the table in place more often.
Jack
Previously 22 cruiser "Loafer's Paradise"
Now 16 cruiser "C-Squirt"
Page generation time: 0.0325s (PHP: 68% - SQL: 32%) - SQL queries: 17 - GZIP disabled - Debug on
