Tom on Icarus
Joined: 15 Sep 2007 Posts: 175 City/Region: Campbell River, Vancouver Island
Vessel Name: Tranquil~C
Photos: Tranquil~C
Posted: Sun Nov 27, 2016 1:52 pm Post subject: I need slippery bunks |
I have read all I can find here on products one can use to make the boat slide on the bunks better.
Without going to an expensive commercial boat trailer bunk product, I was wondering if any brats have come up with an inexpensive, easy to install, home remedy for the problem of too much friction from the bunks when loading the boat onto the trailer.
I have tried using silicone spray on the carpeted bunks and noticed no difference.
I am sure there are many of you out there who have come up with some ingenious solutions to problems like this. I'd love to hear from you.
Cheers, Tom _________________ 22 Cruiser "Icarus" 2005 - 2011
25 Cruiser "Tranquil~C" 2011 - 2019
30 Commander (to be named) 2019 - |
Posted: Sun Nov 27, 2016 4:02 pm Post subject: |
Tom,
I have tried the spray product, "Liquid Rollers" with some noticeable improvement, but that is with a 22 Cruiser, and there is a fair amount of weight difference.
The easiest trick is to be sure the trailer is deep enough into the water at the ramp. I had been noticing some "rub lines" forward under the bow, same lines on each side of centerline. Buffed them out, and then they are back. After consulting with another bunk trailer owner who watched me at the ramp, came up with the fix pretty readily.
His suggestion was to back in with the boat on until it floats off the trailer without any extra heavy pushing. Just untie and pull her back. Then mark the water depth on the trailer sides or someplace, and back in to there to load. The boat floats right up onto the trailer.
Hope that helps, Its cleaner than banana peels.
SleepyC
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
Posted: Sun Nov 27, 2016 5:02 pm Post subject: |
plastic trailer bunk wraps are as easy as you can get. They're made to fit over/wrap either 2x4 or 2x6 wood bunks. |
Joined: 01 Mar 2005 Posts: 7485 City/Region: from island boy to desert dweller
Posted: Sun Nov 27, 2016 5:30 pm Post subject: |
The Glide King bunk sleeves (came on our King Trailer) were the best thing I've ever used with a bunk trailer. No idea if you can buy just those sleeves, but if so, they do a great job. |
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Sun Nov 27, 2016 7:09 pm Post subject: |
I bought a bunk slide kit a few months ago, but now I can't find the brand name or web site. My CD 16 trailer has two 2x6 eight foot bunks. I bought a liner package that was enough to cover the planks and included plastic ends. I just bought new pressure treated planks, put the covering on (SS screws were included), launched the boat, and changed the planks using a battery powered lag screw driver in the parking lot.
I have ablative bottom paint, which isn't slippery when dry. Sometimes people complain that slicks can rub the paint off, but I haven't had any problem, at least not any more problem than with outdoor carpet on the bunks. I can tell the difference between launching and retrieval, as the boat is wet and slicker coming back on. I probably could pour water down each bunk before launching, but I haven't needed to do that. As part of the bunk plank replacement, I was also able to lower the bunks two inches. Between the new slicks and the lower bunks, launch and retrieve is much easier.
Mark
Here they are. Much easier to wrap the bunk when the plank is completely off. Also, the wrap comes in a roll. I let it lay flat on the patio in the sun for a day.
https://bstrailer.com/parts/plastic-trailer-bunk-wrap-kit/ |
Will-C
Vessel Name: Will-C
Photos: Will-C
Posted: Sun Nov 27, 2016 7:33 pm Post subject: I need Slippery Bunks |
I slid this type on to the forward half of our 2 X 4 bunks right over the carpet. Just sent screws in on the sides on the wooden bunks though the plastic slides. They had a boat on them from coast to coast and back. Work well still in good shape.
D.D.
http://www.overtons.com/search/plastic%20bunk%20slides _________________ Chevrolet The Heart Beat Of America |
Posted: Sun Nov 27, 2016 9:29 pm Post subject: |
My latest 22 trailer came with "slicks" on the entire bunks:
like these We put "slicks" on the front 8 feet of the Tom Cat bunks, to allow the sharp bows to slide off easier.
Most "Slicks" are made of high density polyethylene, instead of teflon. But they can be very slippery. and I suggest that anyone using them, put extra strapping on the boat, especially aft. Having bottom paint seems to cause a little more "drag" on the boat coming on or off the trailer.
Many of the 25's sit between the fenders. I always tried to have the aft end of the boat floating, so I could keep the boat centered within an inch or two. _________________ Bob Austin
Tom on Icarus
Photos: Tranquil~C
Posted: Sun Nov 27, 2016 9:48 pm Post subject: |
Thanks for the feedback everybody. Keep those ideas coming if you have success with something.
Cheers, Tom |
jbdba01
Posted: Mon Nov 28, 2016 5:37 am Post subject: |
I saw someone at a ramp had redneck engineered some starboard strips. Effective, but a bit sloppy.
Additional full length strips (which seems a bit over the top) can be found here.
http://www.surfixinc.com/surfix_trailer_bunkslides.html
Most of the strips I've seen ran only about half way down. |
Tom on Icarus
Photos: Tranquil~C
Posted: Mon Nov 28, 2016 1:12 pm Post subject: |
All good suggestions. Thanks everyone.
I need a product or application that won't raise the boat on the trailer much as there is less than 1/4 inch clearance to get the boat into the garage. I've looked at some of the products suggested and found they might be too thick to work for me. I can't lower the bunks anymore either.
I thought there might be some thin(1/16 inch) product out there that is cheap enough to replace as it gets worn out.
This may be a goofy idea but it just may do the trick....
For less than $30 I can buy some of those plastic, roll-up, kid's snow slider rug things and cut them to the width needed...follow me? They are very thin and tough but flexible so they'll wrap around the bunk and fasten to the sides with stainless screws and washers. One negative is the bright colors they come in.
What do you think of this "redneck" idea? Maybe there are other likewise ideas out there.
How much of the bunks should be covered? Several seem to think that only the front half of the bunks.
Cheers, Tom |
Posted: Mon Nov 28, 2016 1:23 pm Post subject: |
Tom, You may be able to find some Polyethylene in 1/16 or 1/8 inch sheets, cut them to fit, and if you are careful, you could heat them on a 2x4 (or 2x6) form to bend over the edges and have them form fit your bunks. It is easy stuff to work with, as in cut, heat and form, and it won't likely come in the tupperware colors of the kids sleds.
SleepyC
Tom on Icarus
Photos: Tranquil~C
Posted: Mon Nov 28, 2016 2:11 pm Post subject: |
Good idea Harvey. I'll look into it. There is a plastics shop in town. I'll see what they have. |
