Recommendation for a fish finder.
Nancy and Bud
City/Region: Nashville
State or Province: IL
Vessel Name: Emma Mae
Photos: Emma Mae
PostPosted: Fri Sep 04, 2020 3:54 pm    Post subject: Recommendation for a fish finder. Reply with quote
Have a Garmin chart plotter with all the maps and GPS.
Looking for a lower end fish finder that doesn't need to have all the bells and whistles but will work well enough to catch fish.
Fishing Table Rock Lake early next month if our outboard shows up before then.
Thanks for any advice/recommendations.
"C-dory's are the 13th step in a 12 step program for sailors."Marc Grove, Wefings Marine
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Fri Sep 04, 2020 5:12 pm    Post subject: Reply with quote
What chart plotter do you have you could just put a transducer on that.
Jody Kidd
KE7WNG
Northern, Utah
Nancy and Bud
Photos: Emma Mae
PostPosted: Fri Sep 04, 2020 6:42 pm    Post subject: Reply with quote
Garmin GPSmap 741xs
It would require adding GCV™ 10 Scanning Sonar Module
PART NUMBER 010-01156-02
$599.99
USD
Way beyond what a stand alone unit would cost.
jkidd
PostPosted: Fri Sep 04, 2020 6:57 pm    Post subject: Reply with quote
Dual beam and dual frequency and clearview are built in just need a transducer should have a port on the back of it for sonar. Sideview requires the black box. Should be able to get a transducer for around $150. Cheapest way. Here's the link to the specs https://buy.garmin.com/en-US/US/p/119867/pn/010-01102-01#specs
Nancy and Bud
Photos: Emma Mae
PostPosted: Fri Sep 04, 2020 7:17 pm    Post subject: Reply with quote
THANK YOU!!!!!!!!!!!! Thumbs Up Thumbs Up
PostPosted: Fri Sep 04, 2020 10:19 pm    Post subject: Reply with quote
I have owned the Garmin 741sx and it is a great fish finder. My bundle came with the transducer. Check your manual and plug, it is possible that the GT 20 TM transducer which is only conventional sonar may work--at about $99. If not then the one with Down Scan and Chirp. Personally I would spring for the Down scan and Chirp--it is worth it. I use the down scan when surveying anchorages as well as fishing.
Nancy and Bud
Photos: Emma Mae
PostPosted: Fri Sep 04, 2020 11:56 pm    Post subject: Reply with quote
Thanks Bob.
Page generation time: 0.0289s (PHP: 62% - SQL: 38%) - SQL queries: 20 - GZIP disabled - Debug on
