the ultimate sewage pump
Post new topic   Reply to topic    The C-Brats Forum Index -> Wastewater Systems
cmetzenberg
City/Region: Santa Barbara
Vessel Name: Kanaloa
Photos: Kanaloa
PostPosted: Sat Nov 28, 2020 2:29 pm    Post subject: the ultimate sewage pump Reply with quote
So i've just removed my sewage ovbd pump...again. This is the third Jabsco 18590. Maybe i should try a new pump? something that lasts a bit longer. Recommendations?
Conrad Metzenberg
07' Tomcat 255 "Kanaloa"
87' Boston Whaler Guardian 17 (BlackFlag, 03-14)
PostPosted: Sat Nov 28, 2020 3:06 pm    Post subject: Reply with quote
I rarely use mine and just about every time I did it starts, makes racket for a while without pumping, then blows the 25a fuse. I discovered that if I shoot fresh water from a hose into the overboard outlet the pump will then work. If I remember to do that before using the pump it works fine.
During the ocean salmon season it gets used more frequently and is not a problem. It’s only when it sits a while after a use that it fouls up. If I do the rinse after a use it will work the first time months later. You might try the reverse rinse before spending the bucks on a new pump that will probably do the same thing.
PostPosted: Sat Nov 28, 2020 3:48 pm    Post subject: Reply with quote
I have replaced the macerator types with the diaphragm type sewage pump. Here are several brands: Dometic, SeaLand T series, Viking 510, Jabsco diaphragm sewage pump, and Gulper by Whale. The rotary macerator have always been problematical to me. They tend to corrode and eventually the vane pump sticks, then the pump overheats, gone....
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Sat Nov 28, 2020 7:20 pm    Post subject: Reply with quote
Conrad,
We had the Whale Gulper black water model with VacuFlush system for nine years on a Regal 2665 with no problems. Eight years out of warranty, the blue retaining ring broke and they sent us a new one for free. Customer Service reps had such great Irish accents that you will find yourself calling them to talk even when you don’t need anything.
https://www.fisheriessupply.com/whale-gulper-toilet-waste-pump
As you know, like most normal folks I find the subject of boat sewage management to be absolutely fascinating. You would need to replace the different length hoses from tank to pump and pump to Y-Connector with the Whale. This would not be a bad thing, since many with more expertise than me about this s**t claim that even the very best hoses will get permeable (smells leak out) after ten years, so it’s time.
We have concluded, after experiences you should not ask about, that the most effective way of preventing boat sewage plumbing issues is to simply never put used toilet paper into it. Put it in a sandwich baggie, seal it and trash it. The Very Best Marine Expensive TP turns into paper mache like clogs. I should have taken pictures for my album!
Our current Jabsco 18590 was still pumping (over 3 miles out in the Gulf) on our last cruise in August, a record 3 years! And I have 2 spare Jabsco pumps (on sale) and a rebuild kit in the garage. I could change out to the Whale, except I enjoy complaining about the Jabsco 18590 so much. If it wasn’t so much fun arguing with AirHead fanatics, I might change over to one of those, as well.
Happy Sewage Management!
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
2024 Yamaha F150xsa x2
PostPosted: Sat Nov 28, 2020 8:43 pm    Post subject: Reply with quote
My answer was to pull all that crap out and just put my porta potti in the head! I keep thinking I should craigslist the stuff, but if anyone is really interested, for the cost of shipping I have a working macerator pump, a y-valve that probably needs new seals, and the commode with the tank under it. (9 gals maybe?). Colby
PostPosted: Sun Nov 29, 2020 12:01 am    Post subject: Reply with quote
Well, on the punny little 22, (no head with hot water and slate counter tops), I mostly use a bucket and bag, BUT if I had a head it would be an "Air Head". Of course, I would miss out on doing all that "plumbing fun". (Just fodder for John in case you are feeling needy Laughing
But each of us have our own deffinition of "Fun" Shocked
cmetzenberg
Photos: Kanaloa
PostPosted: Sun Nov 29, 2020 9:40 am    Post subject: Reply with quote
Same exact thing!
Post new topic   Reply to topic    The C-Brats Forum Index -> Wastewater Systems All times are GMT - 5 Hours
Page generation time: 0.0476s (PHP: 66% - SQL: 34%) - SQL queries: 20 - GZIP disabled - Debug on
