Engine stalls under load only on one gas tank? c-dory 22
wa500
City/Region: seattle
Vessel Name: C-Horse
Photos: C-Horse
PostPosted: Fri Apr 28, 2023 9:04 pm    Post subject: Engine stalls under load only on one gas tank? c-dory 22 Reply with quote
I want to get your thoughts on this one.
One of my fuel tanks will run the motor fine. The other one will stall when the load gets over 1/4th-1/2 throttle, but otherwise will run it fine. That makes makes me thing its a fuel flow issue with only that one tank.
What would me the most likely problem?
PostPosted: Fri Apr 28, 2023 10:44 pm    Post subject: Reply with quote
Sounds like the screen on the suction hose may be plugging up. A short term fix is to disconnect the fuel line from the tank and stick on a short clean piece of tubing. Then blow through the thing for all your worth or use a short burst of compressed air to knock all the sediment off that has accumulated on the screen.
If that alleviates the problem then you'll need to take the pickup tube completely out and clean the screen thoroughly and also look into the bottom of the tank to see if it is in need of a cleaning inside.
This is assuming you don't have separate filters for the two tanks and haven't first checked that.
PostPosted: Fri Apr 28, 2023 11:31 pm    Post subject: Reply with quote
Might also check the tank vent for that tank.
wa500
Photos: C-Horse
PostPosted: Fri Apr 28, 2023 11:48 pm    Post subject: Reply with quote
Where is the vent located? Would cracking the gas cap while underway test for this?
wa500
Photos: C-Horse
PostPosted: Fri Apr 28, 2023 11:50 pm    Post subject: Reply with quote
No separate filters.
Pulling this line off requires emptying the tank I assume but can be done without removing it?
PostPosted: Sat Apr 29, 2023 11:34 am    Post subject: Reply with quote
Vent outlet should be on the outside of the gunwale a little aft of where the fuel filler is. It looks like a silver knob about 3/4" x 3/4". The opening is at the bottom.
Depending on your gas cap, "cracking" it might not be sufficient. Opening it fully will test for the vent problem though.
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Sat Apr 29, 2023 3:09 pm    Post subject: Reply with quote
The hose date of mfg is on the hose (it may have been laying around the factory a few years). The manufacturers advise replacing gas lines at 10 years (though I haven't yet). If all else fails, something to consider at 16 years. Some internal bulges can't be detected. Using E10 gas makes hose issues more likely. Good luck!
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
2024 Yamaha F150xsa x2
PostPosted: Sat Apr 29, 2023 10:05 pm    Post subject: Reply with quote
Another possibility is a malfunction of the anti siphon valve, which is the hose barb at the top of the fuel pick up tube. I have had those restrict flow, and removed that ASV replaced with just a hose barb fitting.
PostPosted: Sat Apr 29, 2023 10:09 pm    Post subject: Reply with quote
MannyBridge
City/Region: Nanaimo
Vessel Name: C-Star
PostPosted: Sun Apr 30, 2023 10:24 am    Post subject: Reply with quote
Also check all your fittings/clamps. Last summer I had a loose one that was allowing air to be drawn in at higher RPM/load. The engine would sputter and almost stall.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Apr 30, 2023 9:12 pm    Post subject: Reply with quote
Thumbs Up Thumbs Up
wa500
Photos: C-Horse
PostPosted: Thu May 04, 2023 1:51 am    Post subject: Reply with quote
It looks like the check valve was the culprit, white powdery stuff was blocking flow. I have it sitting in a vinegar cup overnight. We'll see if it fixes it.
[/img]https://i.imgur.com/IBOC8NU.png[url][/url]
PostPosted: Thu May 04, 2023 2:40 am    Post subject: Reply with quote
They are not all that expensive: I would buy a new one. I have one "out of the box" be bad.
What do you think is the comosition of "white powdery stuff"? Related to ethanol? Water in the fuel? Old sealant?
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Thu May 04, 2023 11:21 am    Post subject: Reply with quote
I agree with Bob - buy a new one and be done with it. The white stuff looks like the remains of some sealant on install and the part doesn't look like it has chemically reacted with anything. It is common they fail.
wa500
Photos: C-Horse
PostPosted: Thu May 04, 2023 11:24 am    Post subject: Reply with quote
Where do you get the new one? Half of the issue would be finding the right thread and part #, so I just dunked it. I see a million on Amazon for $9, but it's unclear what to use.
In any case, blowing through it its obvious its restricted, so testing if its fixed will be easy.
Page generation time: 0.0471s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
