R Beck
Joined: 11 Jul 2024 Posts: 1 City/Region: Santa Barbara
Vessel Name: TBD
Posted: Sat Jul 27, 2024 12:10 am Post subject: Transom Saver on Tomcat 2006 |
Do we need to use a Transom Saver on a 2006 Tomcat if trailering for long distance? |
srbaum
Joined: 30 Aug 2010 Posts: 909 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Sat Jul 27, 2024 7:39 am Post subject: |
R Beck, my opinion is that they are not a good idea. Though you strap the boat to the trailer, while going down the road, the trailer frame moves a bit, which causes the outboard to move in unison with the trailer and not the boat. Seen it, been there, got the tee shirt and saw the damage. _________________ Steve Baum
Homeport of Portsmouth, VA
jkidd
Joined: 23 Oct 2006 Posts: 1674 City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
Joined: 27 Oct 2012 Posts: 3589 City/Region: SW Michigan
Posted: Sat Jul 27, 2024 9:49 am Post subject: |
On my CD22 with the motor in the normal position the skeg is too close to the ground for comfort when towing. I use a piece of 2x3 that gets put into the tilt mechanism to hold the motor in a raised position when trailering. Raise the motor up, insert wood, lower motor until the wood is captured. Done.
Only really need a "transom saver" if the motor needs to be held in a raised position when trailering. This is to prevent the motor from dropping down and potentially dragging from a trim cylinder failure . This is not likely, but just in case, a piece of wood is a lot cheaper than a lower unit. The transom saver should not be connected to the trailer for the reason mentioned earlier.
Both the trim system and the transom experience much higher loads in normal operation than when trailering and are designed for them. |
Captain Starbucks
Vessel Name: DOUBLE BARREL
Photos: Captain Starbucks
Posted: Sat Jul 27, 2024 10:16 am Post subject: |
Trailering on the TomCat is done with the engines in the down position due to height of skegs above ground. There is no need for a transom saver. The load is as shear as it's going to get, not tension. _________________ Current boats
12' Lund with oars
17' Grumman expedition
Previous boats
old 16' Glasply with inboard jet |
Posted: Sat Jul 27, 2024 2:41 pm Post subject: |
I used the M-Y Wedges, plus similar rubber/plastic pieces on both sides of the steering rans to prevent the motors from turning, which is hard on the seals.
My 18' Caracal cat came with a "Transom Saver" and I have used it without issues. There is a spring inside of the square tubing which takes much of the shock load from the bumps. I have my boats strapped to the trailer frame, with one of the yellow ratchet straps snugged up as tight as possible. _________________ Bob Austin
