Propane grill setup.
mlwharton@gmail.com
City/Region: Bellingham
Vessel Name: Solace
PostPosted: Thu Mar 27, 2025 11:04 am    Post subject: Propane grill setup. Reply with quote
Hi all we joined the group a while back. Just starting to reconnect. Curious who has a grill on their boat and wondering about gas tank vents and grill locations. Our boat is a venture23'. I think I'm going to mount the grill off the bow sprit/ rail. Pics of other safe grill mounts would be helpful. Thanks Mark.
Mark Wharton
-Waypoint-
C-Dory Year: 1998
Vessel Name: Waypoint
Photos: Waypoint
PostPosted: Fri Mar 28, 2025 8:37 am    Post subject: Reply with quote
I built a platform in the motor well for my Magma gas grill that can hold the Honda Generator when not using the grill.
Now I put the grill when I am cooking, on a wood box that is storage for my aft anchor. I don't worry about gas tank fumes with an open flame because the vents are outside of the hull unlike portable gas tanks.
This is no different than using an open flame Butane/ Propane stove. Mount the grill anywhere you want in the cockpit.
Mark n' Yuka Elwell
mlwharton@gmail.com
Vessel Name: Solace
PostPosted: Fri Mar 28, 2025 11:11 am    Post subject: Reply with quote
Ok , thanks for the pics. Still working on the best mounting spot for our boat.
BigSwede
State or Province: MN
Vessel Name: Coddiwomple
PostPosted: Fri Mar 28, 2025 7:54 pm    Post subject: Reply with quote
The 23 Venture I recently bought has a mount for a Magma grill on the cockpit gunnel. I don't have a picture handy as the boat is at the shop right now, but I can get one later.
DKennaC25
City/Region: Lebanon
State or Province: IN
Vessel Name: .?
PostPosted: Mon Mar 31, 2025 7:02 pm    Post subject: Reply with quote
I would love to see a picture if you get a chance to. Post one.
2003 C25
BigSwede
PostPosted: Tue Apr 01, 2025 12:32 pm    Post subject: Reply with quote
I will. It is just chrome socket for a pole the grill sits on.
CC Rider
City/Region: Tsawwassen
Vessel Name: CC Rider
Photos: CC Rider
PostPosted: Tue Apr 01, 2025 1:51 pm    Post subject: Reply with quote
I installed a Scotty rod holder receptacle on the forward part of the cockpit gunnel (gunwale?). Scotty also sells a pin for mounting on just about anything, to fit the receptacle. I bolted this pin mount to the bottom of my Sea-B-Que bracket.
I had Scotty rod holder mounts on the gunnels already, but they were towards the aft and too close to the fuel tank vents for my comfort to use for the grill. For the same reason, I did not want to mount the grill on the aft part of the cockpit.
The mount also allows for two rods to be used on the port side, if I ever want double rods on one downrigger when fishing.
MMSI#: 316033635
Page generation time: 0.0458s (PHP: 42% - SQL: 58%) - SQL queries: 20 - GZIP disabled - Debug on
