Klean Heat Shelf Life
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Sat Dec 29, 2007 11:23 pm    Post subject: Klean Heat Shelf Life Reply with quote
We just installed a Wallas 1300 and are using Klean Heat for fuel. I bought three jugs from Home Depot thinking that it may be a seasonal item around here. Scan Marine cautioned that Kerosene deteriorates quickly and that fresh fuel is important. I was wondering what experience others have had with storing Klean Heat for any length of time. How long have you kept it without problems? Do you use any additives in it?
Thanks for any information.
Rob & Karen
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sat Dec 29, 2007 11:57 pm    Post subject: Re: Klean Heat Shelf Life Reply with quote
Rob & Karen
http://zenstoves.net/MSDS/KLEANHEAT.pdf
Sealed in the container, out of direct sunlite & at room temp it will probably outlast all of us. Once you open it I would guess a year! Mr. Green Beer
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun Dec 30, 2007 12:11 am    Post subject: Reply with quote
It is my understanding the shelf-life is 2 years for an unopened container and 6 months for an open one.
Brent Barrett
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sun Dec 30, 2007 1:55 am    Post subject: Reply with quote
I am using 2 yr old Klean Heat right now, just burned about 14 hrs total during my outing this week. No problems. This is synthetically manufactured (formula unknown), the shelf life will most likely be different than kerosene. I also heard (from Scan Marine I believe) that when kerosene deterioates, it begins to leave a residue or precipitates at the bottom of the container. Not sure about that one, but I checked my containers, no solids.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
terraplane
City/Region: chesapeake bay
C-Dory Model: R-25 Tug
Vessel Name: BANJO
Photos: Sally's Sister
PostPosted: Sun Dec 30, 2007 9:34 am    Post subject: kleen heat use Reply with quote
Right now i'm burning a jug that is over two years old...kept in unheated barn area. No problems. I always start on highest setting and shut off in highest setting to burn off carbon,I'm told.
terraplane
C-WEED
City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Sun Dec 30, 2007 1:19 pm    Post subject: Reply with quote
Just make sure the jugs sit completely on the shelf. I had two that got moved around a bit and hung off maybe an inch on one end. And it happened to be the end closest to the wall that you don't see. This will make the container sag just enough to make a nice tiny crack.
Drip...drip...drip... I noticed a moist stain on the outside of the garage foundation block and went to investigate. What a mess...
Chris
Page generation time: 0.0267s (PHP: 63% - SQL: 37%) - SQL queries: 19 - GZIP disabled - Debug on
