CD25 Shoulder Pads
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sun Mar 23, 2008 4:03 pm    Post subject: CD25 Shoulder Pads Reply with quote
I can finally check off another item off my list. I finished upholstering and installing shoulder pads for the passengers. It was low on my list because it doesn't affect ME! But I felt sorry for my guests having to lean against the hard, fiberglass wall and tuck their shoulder under the window frame. Very comfy now.
I made an identical pad for the rear seat just for symmetry, plus doubles as a nice head/backrest for sitting sideways. They are shaped like that to accommodate the reversable front seat backrest. I used high density foam.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Sun Mar 23, 2008 4:39 pm    Post subject: Reply with quote
Nicely done, one of those "why didn't I think of that" projects.
Patti and Barry
formerly C-Cakes, now
rving around N. America
C-batical
City/Region: Pinckney
Vessel Name: C-Batical
Photos: C-Batical
PostPosted: Sun Mar 23, 2008 5:55 pm    Post subject: Reply with quote
What a super idea. I think I will add this to my 'to do' list.
Best regards,
Rollie/C-Batical
Pinckney, MI
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Sun Mar 23, 2008 7:19 pm    Post subject: Shoulder Pads Reply with quote
Hey, those look nice!! How did you fasten the cleats to the side of the cabin? My assumption is that they are glued in place somehow.
Steve
Dora~Jean
Photos: Dora~Jean
PostPosted: Sun Mar 23, 2008 8:01 pm    Post subject: Reply with quote
3M 4200, very tough stuff.
First I drilled the screw holes from the cushion backplate (3/8" plywood) through the 2x2 supports on the bench for good alignment. Then slotted the plywood holes for the large SS screw heads to pass through and slide into place for final assembly. Then painted all pieces with primer and a good exterior paint (2 coats), except for the 2x2 side to be glued.
I cleaned the cabin wall surfaces with alcohol thoroughly. Put 1/8-1/4" beads on the 2x2 supports (bare wood) with them assembled to the cushion backplates (no cushions yet), then glued in place and held tight against the wall with my extension boat hook pressing from other side of cabin. When glue was dry, I removed the backplates leaving the screws in place.
I upholstered the cushions, inserted the foam (cut with an electric knife), then stretched and stapled onto the backplates. Had to loosen the screws about 1/2 turn to allow for the fabric thickness on the backside, then pushed into place and down for a tight fit. About 10-15 hours of designing and measuring, about 8 hours to do the work!
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Sun Mar 23, 2008 8:02 pm    Post subject: Reply with quote
Nice job! Did you do the sewing yourself? I am going to look at do this also.
Steve
Dora~Jean
Photos: Dora~Jean
PostPosted: Sun Mar 23, 2008 8:14 pm    Post subject: Reply with quote
Yes I did, thank you very much. I bought a Thompson Mini-Walking Foot industrial sewing machine new for $450 about 20 yrs ago, it has paid for itself many times over. I learned to upholster from my mom, she reupholstered antique couches, loveseats, divans and chairs to help out with the finances when I was growing up. I helped and watched everything I could. Didn't know I'd use it later in life, just interested.
...and the old coins and paraphenalia you'd find in some of the seat back bottoms, ohhhh if they could talk, and ohhhh if only I'd have kept them...
PostPosted: Sun Mar 23, 2008 8:27 pm    Post subject: Reply with quote
Looks good and very functional - NICE! Thumbs Up Thumbs Up
PostPosted: Sun Mar 23, 2008 8:48 pm    Post subject: Reply with quote
Great project--thanks for sharing!
IT-SEA-BIT-C
Guest
PostPosted: Sun Mar 23, 2008 9:00 pm    Post subject: Reply with quote
PAT PAT PAT -that was a pat on the back for a job well done , nice pics too, looks nice & comfy, great job.....
Al & Pat Parker
City/Region: New Bern
Vessel Name: Knot Home
Photos: Knot Home
PostPosted: Sun Mar 23, 2008 9:08 pm    Post subject: Reply with quote
Hi Steve,
Yes, we agree, very nice idea and job. we saw it this PM b4 all the comments, but had to head out for dinner, so didn't get a chance to send our kudos until now.
Ms Pat likes it, it'll be on our project list for Knot Home.
thanks,
Al & Pat
C-D 25 "Knot Home"
Mainship Pilot 30 "Juust Right"
on the Neuse River at New Bern
W8UT
www.boatanchors.org/C-Dory25.htm
"there is nothing -absolutely nothing- half as much worth doing as simply messing about in boats."
(ratty to mole, Wind in the Willows)
Sea Angel
Photos: Sea Angel
PostPosted: Sun Mar 23, 2008 9:31 pm    Post subject: Reply with quote
Great touch,, Steve. Thumbs Up Thumbs Up Thumbs Up
Now you've done it! I will have to figure out how to do this for Sea Angel.
Can you do this in blue??? Teeth Teeth
Art
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
PostPosted: Wed Jul 13, 2011 8:53 pm    Post subject: Reply with quote
One project done.
My version of the shoulder pads. Thanks to Steve (Dora Jean) for the idea and Camille (Berta's Boy) for the expert sewing.
I made the rear one rectangular to fill more of the space. Since the rear doesn't move like the front seat and since M likes to sit w/ her back there while we watch movies, it made sense.
2" thick, extra firm/dense foam, 1/2" ply, SS screws and 2X2s like Steve designed.
Sarge
City/Region: Edmonds
Vessel Name: Sea Badger
Photos: Gigi
PostPosted: Thu Jul 14, 2011 12:38 pm    Post subject: Reply with quote
The shoulder pads look great and professionally done. It's the kind of thing the factory might consider, even as an option.
-Sarge
2001 2150 Bayliner, sold
2007 CD25, sold
2007 Harbercraft Kingfisher 2850, sold
2011 Stabicraft 2250SC, sold
2011 Eastern 18cc
Blog: http://theseabadger.wordpress.com
View user's profile Send private message Visit poster's website AIM Address
Page generation time: 0.0417s (PHP: 66% - SQL: 34%) - SQL queries: 26 - GZIP disabled - Debug on
