22' C-Dory Cruiser 2003 (C-Dory.com)
White with Deep Blue factory accent trim
Hull ID#: CD022057G203
* Boat features listed below
Suzuki DF 90 Four-Stroke 2003 model with 96.5 total hours
Stainless Steel Propeller - Three Blade
Motor Serial #: 09001F-421501
Nextrail Tandem Axle Boat Trailer with Disc brakes on each axle
Trailer Vin #: 1N9BB23272B171248
* Stainless Steel Bolts and Nuts in Main Frame
* Aluminum Mag Wheels
* Galvanized axles
* Cypress Bunk with Marine Carpet
* Aluminum Guide-Ons with PVC
* Heavy Duty Aluminum Cross Braces
* Submersible Lights (LED)
* Model 21 - 23 Tandem
* GVWR 6000#
* Trailer weight 800#
* http://www.nextrailofamerica.com/
22' C-Dory Cruiser Boat Features:
* High (Tall) top -Increases interior headroom from 6'2" to 6'6"
* Mermaid Marine Air 9,000 BTU (Model M-9) Air Conditioning System
- Mermaid Digital, Programable Climate Technology Thermostat
- Includes Foot scoop, seacock, water strainer, 4 supply grill ducting kit, and
electrical connection kit
- Weight is 48lbs
- Cooling capacity is 800 cubic feet
- Bought from Mermaid of S.W. Florida, Inc.
(http://www.mmair.com/marine_division/ai ... onditioner)
* 110V 30 Amp Shore Power
* 30 Amp Breaker Box Panel
* Inverter - 1750 Pro Watt by Xantrex with Remote Switch & GFCI Protected 110V Cabin Outlet
* Wallas Diesel Stove & Heater - Exhaust gases and water vapor vent overboard
keeping cabin fresh and dry
* Simpson-Lawrence Sprint 400 Anchor Windlass with Delta Anchor, Chain & Rode
* Hydraulic Steering by SeaStar
* Hydraulic Trim Tabs (9" x 18" each) by Bennett - http://www.bennetttrimtabs.com
* Flojet Automatic Washdown Pump (Pressure Demand System) - Includes hose and quick disconnect fittings
* Four (4) Batteries
- Two Deka Heavy Duty Marine Deep Cycle Batteries with 650 CCA each
- Two Nautilus Marine Starting Batteries with 525 CCA each
* Forward Facing Passenger Seat - Color-coordinated Blue
* Blue interior cushions - Color-coordinated Blue
* Fully-screened, Cockpit Canvas (encloses back end completly) - Color-coordiated Blue
* Sunbrella Bimini top cockpit canvas - Color-coordinated Blue
* Snap-in Sunbrella covers for all windows - Color-coordinated Blue
* Snap-in Floor Carpet (Cabin & Bow) - Color-coordiated Blue
* Front Opening Center Window by Diamond Sea Glaze - http://www.diamondseaglaze.com/
* Rear Opening Door Window by Diamond Sea Glaze with Window Screen
* Two Side Opening Windows by Diamond Sea Glaze with Window Screens
* Door lock - Cabin door key lock
* Water system - A 20 gallon water tank fed to a S.S. sink by a foot pump
* Swim Step with Ladder - Located on port side
* Cockpit Floor Boards - Keep cockpit dry from standing water
* Chemical Toilet by Mansfield
* Port and Starboard Electric Wipers - Each is a sealed unit with self-parking
* Bilge pump system: A 1100 G.P.H. pump Rule bilge pump with automatic float switch
* Fuel Capacity - Two, 25 gallon tanks for 50 gallons total
Crusing range at 4.5 mpg = 225 miles
* ICOM IC-M402 VHF Marine Radio with one-touch Distress calling button - http://www.icomamerica.com
* Shakespeare Antennea
* Fuel Flow Meter - Fuel Management System monitors GPH (Gallons per Hour)
* Garmin 168 Sounder GPS Chartplotting Receiver & Depth-finder
* Suzuki outboard trim indicator
* Suzuki Voltage Battery Charging indicator
* Never stored in water
* No bottom paint
* Always stored under cover
* Always washed after each use
* Waxed several times a year
* Excellent condition and glossy appearance make this boat impossible to tell from brand-new as
it has only 96.5 hours total operating time
* $72,400 invested
* Offered for sale at $48,000 or best offer
- Boat may be previewed at my business at Fernandina Beach, Florida (30 miles from Jacksonville, Florida)
MapQuest Link
* Buy now and attend the 09/21 - 09/23 - North Carolina C-Dory Gathering at Whittaker Point Marina in style
Why buy a C-Dory? Relaxation as best described by El and Bill in Halcyon Days (a favorite web site of mine): http://www.geocities.com/bill_fiero/relax.htm
While I am sad to sell this beautiful C-Dory, she deserves an Owner who will use her more often than I have been able to. My
charter fishing business (http://www.floundergigging.com) has gotten to the point where I am doing so many charters, at times two charters per night,
that I don't have the time or energy to use this fine boat as often as I would like. I hope the new owner will enjoy her as much as I have.
* Galvanized axles
* GVWR 6000#
- Weight is 48lbs
* No bottom paint
* $72,400 invested
MapQuest Link
