Lighthouse Express
- Joined
- Jun 16, 2012
- Messages
- 83
- Reaction score
- 0
- C Dory Year
- 2004
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- CD025060J304
- Vessel Name
- Lighthouse Express
Since I purchased my 2004 CD25 I noticed the smell of fuel in the cockpit. Stronger with the canvas enclosure or warm weather. The fuel smell is emerging strongest from the rear starboard side below the splash well.
Am I glad I quit smoking when I was 24...
I did check the following:
*Fuel stains of any kind below cockpit deck where possible
*Razor filters for leaks
*Dual engines fuel lines for seepage or wet spots
*Fuel supply 90 degree brass connectors for leaks or cracks
*For blockages of the two vent lines
*For leaks around the gas level sensor unit
Since the 2004 model does not have a removable cockpit floor (darn thing) I only was able to take a look at the main filler hose and vent hose via mirror and flash light through the round access hole above the gas level sensor. Nothing obvious with the very limited view I had.
No obvious leak that I can find...
Perhaps there is a common problem with the 2004 CD25 fuel system I don't know of???
I got a brand new Magma BBQ grill I want to try out...
