2022 C-Dory 25 Cruiser - F200 DBW, 730 hrs, loaded, $149,000 - Arbor Vitae, WI
Kiteman
Sep 24, 2026
5
1
Location
ARBOR VITAE
2022
25 Cruiser
Pura Vida
FOR SALE: 2022 C-Dory 25 Cruiser — Yamaha F200 Drive-by-Wire, Custom Aluminum Trailer — $ 149,000. Location: Arbor Vitae, WI. One-owner, purchased new in 2022. 730 hours. Always stored indoors, meticulously maintained by a Yamaha-certified tech (available to confirm the motor's condition). Set up for off-grid cruising — solar, lithium, water filtration, Airhead composting head, and a stove-to-pressure-sprayer hot shower (no hot water heater or holding tank to deal with). Has done Vancouver Island to Glacier Bay, the FL Panhandle to the Keys, and all the way around Lake Superior, with trips up to six weeks aboard. 3.0–3.2 mpg at 20 knots, 11" draft with the kicker/engine up.
ENGINE/POWER- Yamaha F200XCB drive-by-wire, stainless prop, 730 hrs- NEW Yamaha 9.9 high-thrust kicker, electric start, on a MiniJacker mount with steering bracket to the main engine- Permatrim, Bennett trim tabs- NEW Interstate cranking battery
ELECTRONICS- Lowrance HDS Live 12 w/ C-MAP Onboard- Halo 20 radar, Point-1 GPS antenna, NMEA 2000- Icom M330 VHF, Ritchie compass
ELECTRICAL/SOLAR- Solar panel on roof box, 135Ah lithium battery- Victron DC/DC charger, solar controller, inverter- KISAE Abso AC1220 20A charger
CABIN- Sleeps 4 (dinette + V-berth w/ memory foam topper)- Wallas cooktop/heater, AC/DC fridge, 2 Caframo fans- Airhead composting head, stove-to-sprayer shower- 21-gal fresh water, UV filtration, outside spigot
DECK/HULL- Custom roof rack w/ Inno box- Bert's rod holders, Seasucker holders- Windlass w/ rode/chain/Delta anchor- SeaDek non-skid, ceramic coating (2025), Armus Hull Pro below waterline
TRAILER- 2024 custom Owens & Sons aluminum, 10,000 lb- Torsion axles, elec-over-hydraulic brakes- NEW tires + spare, bearings freshly packed
Check out the full listing with pictures/video on Boat Trader: https://www.boattrader.com/boat/2022-c-dory-25-cruiser-10379647/
That's a beautiful boat, do you happen to have know the length of the boat with the engine in the up position? Thanks in advance!!
Are you wanting on or off trailer measurement? My best guess is around 28’6” off trailer. I can measure tomorrow if you need an exact.
Thanks, yeah I'm looking for trailer off, I'm on the waiting list for a 25' slip, but the hard limit is 28. Really nice boat, looks like you've taken wonderful care of it
It is in amazing condition. It looks new. I'll measure tomorrow and let you know an exact measurement, since I'm going to the hangar anyway.
While you're out there, could you also get the length on the trailer as well as the height on the trailer? Thanks, very much appreciated.
29.5’ engine up
28’ engine down
Anchor would add 1’ to each measurement
35’ on trailer
11’ tall on trailer
29.5’ engine up
28’ engine down
35’ on trailer
11’ tall on trailer
Our new to us 2006 25 Cruiser will fit in our shop with a 10’ 0” height door with the low rear arch. We are replacing the radar which will be mounted on a fold down bracket to stay under 10’. This is huge for us as it allows keeping the boat at home in the shop to tinker with it all winter. 🙂
