Jack in Alaska
- Joined
- Aug 17, 2004
- Messages
- 1,192
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 26 Pro Angler
- Hull Identification Number
- CD026021I405
- Vessel Name
- HIGH TIDE II
Today I checked the oil on my 1997 90 HP Honda. It was milky and frothy indicating water in the oil. I tasted it and it was not saltwater. Called the local repair shop. He asked if I used it to troll a lot. I do. 35 hrs. at 700 rpm since last oil change. He said it was probably a stuck open thermostat which did not let the engine get hot enough to evaporate the water that came from condensation. I checked the thermostat and he was correct, it would not close. Changed oil/filter and went fishing again w/o replacing the therm. Oil slightly frothy again. Found a new therm. and installed it and will change oil/filter again before going fishing.
Has anyone experienced this sort of problem????
