Simple answer: Check he part numbers, if they're the same, GREEN LIGHT.
Thinking further: Is there a regulator on the alternator or motor?
If it's internal (inside the alternator) , probably yes.
If it outside the alternator, and if the outputs (amps) are different, maybe still yes, but maybe no. How different can it be???
I'd check with several Honda technicians to get their opinions. The factory tech rep would probably say "no" just to be safe and not recommend something non-orthodox. Safer to stay inside the box, etc.............!
All this assumes that the physical fitment of the two alternators are the same.
Do the two alternators have the same output? (amps?)
God Luck!
Joe. :teeth :thup
