A
Anonymous
Guest
Ah, my first post to the C-Brats site, and it’s yet another battery question.
I just acquired a 1984 22’ C-Dory. The battery boxes were brittle and I’ve bought new ones. The old boxes were mounted on rotted wooden bevels in the well-drained space in front of the transom.
The battery boxes were not mounted on the level, but leaned aft at about 7-degrees. Holes were drilled in the boxes to allow drainage.
Here are the questions I’ve come up with so far:
1. Why should a covered battery box need to drain? If the battery’s loosing acid, shouldn’t this be kept in the confines of the box?
2. Shouldn’t the batteries be mounted as close to level as possible to ensure that the plates are evenly covered by the acid?
3. If the battery boxes are supposed to be mounted off plane, what is the optimum angle recommended?
4. I was planning on building the battery box mounts out of some mahogany scraps I’ve got left from other projects. Some marine Waterlox over mahogany seems to me like a fairly bullet-proof approach. What do you folks think?
Tom Herrick
Tom Herrick
