Active member
- Joined
- Feb 23, 2012
- Messages
- 3,990
- Reaction score
- 4
- C Dory Year
- 2002
- C Dory Model
- 22 Cruiser
Hi folks,
I have a Victron BMV600S battery monitor wired into my boat, and have recently realized that I failed to consider something when I installed it. Hence I "get" to order a new house battery :cry So this thread is partly for discussion and partly to (I hope) save someone else from a similar fate (although maybe no-one else would be so stupid
When I hooked up the battery monitor, I did have some thoughts about long term slight load when in storage, but I guess I kind of shuffled them under my mental rug, partly because I wasn't sure what I might have to re-set after shutting it off, and I had a number of other (more appealing things) to be thinking about. I figured I'd figure it out later....
Silly thing is, I was very careful when I wired things up, to be sure to make it so that when I shut the battery switch off, things were OFF (except for bilge pumps ,and... battery monitor). I even re-wired the ACR to eliminate its parasitic load (that was an easy choice, because I always want it off when the battery switch is off). So, the only things that are "hot" on my boat, when the battery switch is off, are two bilge pumps, and the battery monitor.
Of course I let figuring out the battery monitor slide, and then put the boat in storage over the winter. Bonehead move. Then a couple of weeks ago I got a PM from someone asking how I had handled the positive supply wire (to the shunt) and the corresponding load when in long term storage. Erm... :sad
Noting that I had killed my battery (11.4v when picked up from storage... ouch), I decided I had better get to the bottom of this before putting in a new one. I searched the web a bit and while I found many discussions of battery monitors, I found no mention of this issue (maybe it is so simple that no discussion is necessary). So I called Victron North America to ask them a few questions:
1) If I disconnect the battery monitor during longer term storage, what do I lose? Some history, probably, but what about the basic settings? Do I have to do those again each time?
2) Do I just put a switch in the red power wire (small wire from shunt to positive power post)? Anything I need to know?
The fellow I spoke with (Rich Shea) wasn't completely sure about what would be lost or retained in memory. He is checking and will get back to me. He also mentioned that I could disconnect the cable (cat 5 type connector) from the back of the monitor face and that would do it. I don't want to do that ultimately, because I want a switch right by my main battery switch* but I would still like to know if disconnecting the monitor head by the cable is a viable option, for the record. I am not clear on this because there is a printed circuit board on the shunt as well, and wouldn't that draw power? So I added that third question to my follow-up e-mail to him. I will report back to this thread as I find the answers to my question.
In the meantime, I'd recommend not doing as I did. Worst part is, I should know better! I mean, I'm no electrician, but still. There is something ironically annoying about killing the house battery with the battery monitor :amgry
*I want a "real" switch back by the main battery switch so that I can decide upon leaving the boat "Is this shorter term, or do I have a charging source while I am gone for longer term, so I just turn off the main battery switch; or is this longer term, "unpowered" storage so I want to turn off the Victron too?"
