Hi folks, just a question. I'm running a tandem road runner trailer with bearing buddies. I had the trailer all serviced in mid August. I check my bearings each morning to see that the little plate in there can still be moved a bit, if not a couple squirts of grease go in. I stop after the first 40 or 50 miles and check for heat. So far all are running about body temperature which I think is pretty cool. One on the back seems to want a bit of grease every few days. When I first started out they were all slinging grease so too much in there to start with. I will keep on checking daily and adding a bit of grease but am wondering what others do and is it normal for one to run dryer than others? I had a nail removed from my truck tire in Susanville and so had the boys lift the trailer and check all around for grease out the back and for play etc. All was good. I have about 1800 miles on the trailer and all the tires look new so I think I'm in good shape. How do some other long haulers deal with bearing buddies? Thanks all George
