wanna-abe
Gluing anything to aluminum is tough because it usually has an oxidized surface that comes off rather easily, breaking the bond between between the two materials being glued together.
When painting aluminum, (which involves a similar process in bonding as gluing), the surface needs to be roughed up with sand paper, and then etched chemically with an acid to remove any oxidation layer, then quickly dried and the paint applied before a new oxidized layer can develop.
Other problems one has to contend with are the fact tht the aluminum and fiberglass expand and contract at different rates when heated, and that they have different amounts of elongation when stressed or bent. Both of these problems tend to helf break the bond between the glue and the two materials.
My best advice is to screw, though-bolt, or rivet the aluminum and fiberglass together if at all possible. Mechanical bonding beats chemical bonding in this case.
I'll let others with more experience with adhesives recommend which ones to use. The best choice may well involve the exact application you have in mind, so I would suggest you describe in greater detail what exactly you're trying to do.
Hope this helps!
Joe. :teeth :thup
