I do think our C-Dory factory Guest charger is not ideal. You have to run the generator for a while to build up the batteries after an overnight. We tend to stay anchored for a day or two and we don't run the motor each day so the generator gets used. I know there are some good threads on battery charger options. I don't know if we should replace the Guest and keep it as a spare or just wait until it dies.
The guest factory chargers are basically top off, or recharge type of chargers overnight on mains power, not geared to heavy use when cruising. We put in a 25 amp Mastervolt as our primary charger for the start and house battery. We have a separate battery for the freezer (all batteries are AGM group 31 from Sams Club), and we are on the 3rd year of usage. They are cycled heavily when in use, and holding up well. For charging the freezer batter, we use one of the West Marine 30 amp "portable" chargers, and run it directly off the generator when staying for a day or so (our 2006 90 hp Honda only puts out 17 amps--part of which is being used for the engine and electronics when under way)--but many days that is all we need to keep the batteries up (using about 3 cu feet of freezer and refer space). The West Marine charger allows a longer bulk phase of charging --we will be at 20 to 30 amps for over an hour and then it begins to taper to the absorption phase. The AGM battery allows faster charging, but we monitor battery temperature manually. I would keep the Guest charger and use it for "mains" charging at home or the dock.
With the guest charger you start out with 5 to 10 amps/bank--and that is max. The charger tapers off to half that fairly quickly--so it takes hours to get the battery fully charged. Even with the larger charger, when pulling heavy loads off the battery, you have to run a long time to get that last 10 to 20% of charge. So you basically cycle between 40 to 50% charge, to 80 to 90% charge. For example still drawing 60 amp hours out of a 120 amp hour battery.
Great Video--with fairly advanced techniques. Some new material and technique--including the "Fabricator Sewing machine"--which is a break thru in light commercial machines, with the full torque, at very low speeds. But not for the beginner unless going into the business. Wonderful story about the sewing class! Hopefully Alicia has a heavy duty machine (Its for the boat!) to handle the heaver fabrics if you begin to to canvas work. It can be a lot of fun, The projects you have started are fantastic places to begin.
In going thru the video, I noted that Shelterite fabric was used for the "frame"--
There is a great PDF on
Sailrite Outdoor Fabric Selection guide Well worth looking at for those who want to learn about various types of marine fabrics. Then go to the PDF for each fabric specs to learn more about them and applications.
The amount of power used by refrigeration units varies a great deal with ambient temperatures, and the amount of power produced by the solar panels varies with the amount of sunlit. Hotter in S. Florida or Az desert, but full sun; PNW cool, but more often cloudy...Often these balance out.
