Catch 22
Member
- Joined
- May 1, 2008
- Messages
- 385
- Reaction score
- 0
- C Dory Year
- 2004
- C Dory Model
- 25 Cruiser
- Vessel Name
- Catch 22
I have not used my boat as much as most others, as i have only really had it on the water for about a month now, but in that month I have used it quite a bit, in all kinds of conditions. From my exprience, it seems to handle and take chop much better with four people on board than two, like the more wieght, the better, even up on plane when it's just the flat portion of the boat in the water. I have always tried to keep my (previous) boat, as light and empty as possible, to save wieght and space, this is a bigger boat so i may not be as important but i have it in my head that keeping wieght down on a boat is good. If i go out fishing for the day or overnight, it almost seems like I would like to have some ballast on board just to be able to go over chop better, but then i think, for longer trips or cruises, when i would be more loaded with gear, I'd like to have no extra weight on board...
The reason I ask is, over the winter I will be gutting the interior of the boat, down to the hull, and starting over, including the rear bulkhead, all the original wood is in less than satisfactory shape. I am considering building all the future interior out of carbon fiber panels and glassing it all to the hull, making it a much lighter and stronger hull,with less vibration and noise. I replaced the original transom box with a smaller lighter composite box, but then added new heavier duty fuel tanks, so I think the boat is at about the original wieght. So, should i try and make the boat as light as possible, or is there any risk involved. Has anyone ever encountered a situation where they thought the were over loaded, or too light...? In the racing world we build as light as possible so we can add ballast where we want to when we want to...
