UncleRichie
I have a 1999 75 hp it has over two thousand hours on it and runs good .the only problem with the carbs was not draining them when I put it up for the winter. Each carb has a bowl drain if you turn of the gas and run the engine till it starts to run out of gas then shut it off ,take the lid of and drain each carb dry . After I did this I have had no problems at all with it. The carb rebuild kits are a joke three o rings per carb ( 75bucks) . I found that that you can reuse them with no problems. Working on them is very easy just take a pic of the side of the motor before you start ( the linkage is complex and the pic makes ever thing go togeather easy) . I have had them apart twice ( the second time was not my fault bad gas in Canada) .
If you take them apart mark the adjustment screw and count how many turns out from all the way in and set it back to the same ( just do one carb at a time ) from start to finnish should no take more then a couple of hours ( take your time ). The Honda carbs are some of the best carbs I have worked on very well done. I hope to get at least another 4000 hrs on mine as long as I take care of it.
Richard
Richard
