CB Light
toyman
The light on my main 110V breaker isn't illuminated, neither is the reverse polarity light - everything seems to be working fine and the other indicator lights on the panel are working - do I have a problem ? Don't really want to fix it until there is a problem, my "fixes" usually create problems enough.
Dave, I assume this is when you're plugged into shore power?? :wink:
If so, and you don't have polarity reversed, that light should NOT be on.
Do the 110V outlets in the cabin work? Are any of the other lights on the shore power panel illuminated (water heater, outlets, etc)?? Sorry, on edit, you said they wefre.
If they do, then there is just an indicator light problem on the 110v main breaker, not to worry, you can replace it at your leisure.
If it's more complicated than that, give us some more information...
