Being in Central Texas, I have decided I need A/C in the cabin. I have decided to install a window unit, very similar to what Tex has done with Bixby’s Cub. (For several reasons, I do NOT want to cut a hole in the roof. Radar, already using that roof space, etc, etc). I have removed the inner frame (about 20 square head screws) and have removed the gasket from the exterior. I can see the edge of the glass. However, it looks like the glass is epoxied to an inner frame and around the edges. This is a very thick, black, very “gooey” substance.
Question: Does anyone have experience getting the rear window out, and what technique did you use to remove or “pop” out the window? It looks like it must go out to the rear of the boat, but I really don’t want to break the glass. Any ideas are appreciated!
Thanks!
Thanks!
