CD25 Trailer Brakes
Dora~Jean
Active member
Mar 9, 2004
1,522
4
2003
25 Cruiser
Hull Identification Number
CD0250171203
Dora~Jean
After 6000-8000 miles I decided to check the Kodiak SS disc brakes and rotate the tires. The first disc I checked was pretty thin, so called Pacific Trailer and ordered all new pads. Pleasant surprise, a set of ceramic pads per axle was only $29, and, they were on my doorstep the next day!
Here's a picture of the new set vs old:
The last wheel's brakes were all the way down to the rivets. The old discs had warning indicators (screamers) on them, but they did not sound off at all during my last trip, maybe because the pads wore so unevenly. Also, the rotors were supposed to be SS, they aren't (obviously), called Pacific, they said they quit putting them on because they warped too much. So they switched to just Cadmium plated steel. Anybody else heard this? Next changeout I'd like to put true SS rotors/hubs on.
A neat trick to raising a 7500 lb boat/trailer is to lower the tongue within inches of the ground, then place a couple of sturdy jack stands a few feet between the rear axle under the frame. Then lift the tongue about 3 ft. If the wheels still aren't clear (mine weren't), then place a small bottle jack between the two axles under the leaf spring center support and lift until the tires clear the ground. This is a good safety factor to have 2 separate supporting methods while working on the tires and brakes. I'd use this on the road also if I need to change a wheel.
A completed brake assy (and don't forget the antisieze compound for the lug bolts):
Steve it looks like the caliper was pulling that outer pad in to contact the rotor and that it was dragging when released.... normally the rotor runout is enough to push that back....was it stuck ???
Joel
SEA3PO
Yes I wondered about that too. Probably should've lubed (somehow) the bushings that the calipers ride on, might have to do with it now that you mention it. All four sets wore about the same, uneven top/bottom and inside track vs outside, and only the outer pads were heavily worn, inner pads only 1/4 worn or less. So that may be the answer, dragging calipers.
Thanks Joel, I'll take a look at them before hitting the road on the Delta trip.
Steve,
You may want to stick with the steel rotors. I have the SS rotors on my king trailer and king is also not using them any more. The SS rotors score easily and I think that adds to pad wear. When my rotors need replacing I will go with steel.
There have been several posts about problems with the SS brakes.
Steve
Steve, thanks, that's the kind of feedback I was looking for. SS is pretty soft as metals go, understandable on the scoring, and if the design isn't well ventilated, I can see how they'd warp also. Someone will solve it someday I'm sure.
